Everything posted by 885
  1. Anyone have a video of the performance
  2. Have a filson sweep tub and it's nice. I imagine their headgates are of the same quality
  3. I don't know what the big deal is with SAE vs metric. They all cross thread the same 🤷‍♂️
  4. I know several manufacturers recommend replacing coolant at 100k. Part of the replacement has to do with the coolant additive package breaking down over time and the coolant becoming acidic. Which can react with the aluminum and induce voltage, I've heard up to around .5 volts, which in turn can cause problems with anything grounded to the engine block. Essentially it makes the car act like it has a bad ground
  5. 885
    2+2 question
    I assume the front axle was specific to the 2+2 and not something that was scavenged from an existing product?
  6. 885
    2+2 question
    I have never been around a 2+2 in person. They just weren't sold in our mountains. But I have always wondered how much flex they have for uneven ground. I know there is a pivot in the middle for steering articulation, but how did they handle the articulation of going on uneven ground like crossing ditches, plow furrows, etc?
  7. I know you said fried, but the "oil-less" or air fryers make a delicious turkey. We have one by charbroil called the big easy. To me they beat the socks off a fried turkey and you don't have to worry about the house burning down.
  8. There may be a damaged wire in the harness that is intermittently opening or shorting out causing the problem. May need to do a wiggle test on the harness in the area that was damaged. Also look up code description on all data or ship key to understand the system and it's operating parameters. Otherwise it's all guessing
  9. I am not a Ford tech. What does the battery current read with the vehicle running and does the charging system work. Has the battery been tested with a good tester. If the battery is leaking voltage between the cells the start stop may disable to conserve battery integrity. might be as simple as a battery issue and it's charge acceptance based off the current sensor. The vehicle may think that the battery doesn't have enough reserve capacity to run the electronics with the engine off and still have enough juice to crank the car back up. Body shops are notorious for leaking keys on and deeply discharging batteries which isn't good for the battery and can damage the cells. Batteries now days suck and are kind of fragile. Especially with all of the electrical demand on cars now. When a new battery is installed on a Ford the battery life needs to be reset
  10. Not trying to bring religion into anything, but look up Chip Ingram. He is a pastor and has a good multi part video series on parenting and discipline. It's called Effective parenting in a defective world. I believe it can be found on YouTube. I recommend it to everyone I know and especially my friends who are new parents. That said I know that no 2 children are alike and some are more difficult than others. I was one of the difficult ones and grew up in a home that had a discipline structure that was similar to what Chip promotes. I could have turned out rotten, but my parents stuck with it and I turned out pretty well. I've always been told to be parents when they are little and after they move out you will be best of friends. It held true for me
  11. 885
    Nissan Rumor
    So far at work we haven't seen any major or common issues on the new frontiers. I have high hopes for them in terms of reliability. Even in the old body style that had the first year 3.8 we haven't seen problems and they were the first year model for the new power train. The base architecture for the motor is the vq 6 cylinder and it was a pretty good engine family. As I said earlier the transmission is new, and outside of the park recall no real issues that we have seen. There have been a couple of the old body style 9 speeds that have made it up to the 60k mile mark. I think that is about the highest mileage I've seen on the 9 speeds so far, so about 20k miles per year, and no problems. I actually drove a 22model a couple weeks ago 4 hours each way and I thought it was pleasant to drive. Once you get used to the abundance of gears and consequently more shifts that happen it's second nature. They will shift to second gear in the parking lot but it's to be expected. When compared to a 5 speed it seems excessive to some people. But twice as many gears means twice as many shifts. I never had a situation where I felt I needed more power. And the fuel economy I thought was pretty good. I got 25.5 driving from mountains to lowlands, and back. With a good mix of stop and go city driving and highway driving. On the highway portions I was getting 27.1 according to the display. I didn't hand calculate the milage but given I drove 8 hours round trip and a couple of days of around town driving on one tank of gas, I feel it was pretty accurate. I feel that they did a good job updating the frontier, modernizing it enough to stay current and keeping it's reliability. They are a solid choice that I recommend.
  12. 885
    Nissan Rumor
    Yes, Nissan has decided to leave the half ton market according to the news articles. It is a very tough market to break into. The first gen titans were pretty tough. However they didn't get updated for nearly a decade which really hurt their chances for future success. The recall is for a parking pawl issue, Nissan didn't build the transmission. It is a zf unit but Nissan will be stuck with the bad press for a component that they didn't build.
  13. Sad thing is a lot of pressure gauges are dummy gauges that won't show a problem until there is less than 5 psi of pressure. To me that is way too low to be getting sufficient lubrication to the overhead cams. I have personally checked oil pressure in a vehicle that had 3 psi and the gauge read normal. No warning lights
  14. I like the looks of the old cargostar. I've never driven a cab over, always wanted to but never been around one. thought they looked neat though.
  15. I just want to know how you guys keep the worms out of the corn. We always lose an inch or two of the end of the ear to worms.
  16. Dumb question, but are the bellhousing patterns on the industrial the same as a ag 282. Meaning does the ag 282 have a sae 3 pattern or does it have a different rear cover
  17. I think lee will make custom dies. Give them a call
  18. We mow alfalfa 4 cuttings per year and cover crop of wheat and ryegrass from our corn fields. We generally only get 3 day windows to make hay. So conditioning is a must for us. We did come across a set that was interesting to me. https://www.bdrollers.com/the-crusher-hay-conditioning-rollers/ They claim to reduce drying time as they are a full contact roller.
  19. We have the odd rock in our fields that may go through a discbine. How do the steel rollers do with rocks
  20. How do the Massey rollers work in alfalfa. That is our primary crop.
  21. I'll have to check out finzer. Apparently we have one a few hours away in nc. Do you just ask if they can recondition rollers, i assume every location has the same capabilities.
  22. Today went south while mowing hay, the conditioning rolls on our New Holland 7220 discbine separated. Long story short new Holland wants 9000 for both rollers. I found a company in Kansas that will recondition them for 4000 including freight to and from. The company in Kansas was ag belting outlet. Anyone heard of them before or used their products? Or know of another company that refurbishes rollers?
  23. The problem is trying to find 2 healthy guys. There has been no one willing to do manual hay labor here since the late 90's. And it isn't as inefficient as one might think. We meaning 2 people have baled and stacked in the barn 1000 bales in an evening with a Kuhn's system. We used to have a new Holland 1034 bale wagon and for us it works better to use a accumulator. In our sheds we can get more in than with a stack wagon. The wagon was 7 bales high. With this we go 9 bales high and 2 packs wide. Couldn't do that with a stack wagon due to the width. We use 2 trucks and trailers so per trip we can potentially take 300-320 bales. That would have been 3 trips with a stack wagon. I view the accumulator bale packs as a round bale shaped different. When you look at it that way then there really isn't much difference in them. A pack of 10 weighs 6 to 700 pounds and a dry 4x5 realistically isn't much more weight. It takes the same time to load a roll on a trailer as it does to load a pack of square bales. And stacking in the barn is the same way. Plus you can charge same price in the field as in the barn since you can load for the guy in no time.
  24. Our baler is a new Holland with the hydraulic tension. We run the pressure in the middle to lower side of the green on the gauge. The adjustable hay doors/wedges are removed and it makes a tight bale. We used it on a nh 565 with I think 2 wedges removed and maybe backed off the springs a little. The stacking on wagons depends more on operates ability but it does pretty good. I usually throw a strap on the rear when getting on the main road.
