gafarm49
Posts posted by gafarm49
25 minutes ago, acem said:
I didn't realize they grew citrus in GA. I looked them up, they are like mandrin oranges?
yes they are a mandarin, seedless easy to peel and very sweet
2
6 hours ago, acem said:
Glad you got your ac working good.
What kinda citrus you raise?
satsuma
On 6/17/2023 at 8:47 AM, HydroTek said:
A push-pull diverter and flow control valve would be the simplest setup to use
you could sub in a 2 spool valve if there is a need for an extra remote -- but one spool would be dedicated to the flow control
I modded a push-pull diverter and flow control under the cab then ran the control rods thru the floor, near the RH console -- one for the diverter and another for the flow control
There is no priority valve on the '86 series with open center -- and connecting the planter fans like this will cause some variation when lifting the planter . The full flow still goes to the lifting operation, and since the return from the valve stack is supplying the fans you would notice some pressure fluctuations -- as long as you do not hit relief when the planter lifts, the fans will still operate -- other wise flow at the valve stack power beyond port stops, while the main relief is open
So with this setup where would be a good place to install a temp sending unit for the hyd fluid and what temp would be too high? Would it help to run more fluid? I already run 5 gal over. So much of my peanut equipment has hyd motors it would be neat if I could use these tractors more. Even thought about a cooler added somewhere
7 hours ago, Dirt_Floor_Poor said:
What exactly is gin trash composed of?
its leaf , lint and stick particles left over from the ginning process. Piled up and composted
1
1
thanks alot!!! I may try this this winter and may be bothering you alittle if thats ok
1
7 hours ago, HydroTek said:
Maybe, ...the mod I done ran a spray pump
15 gallons enough for that planter ? -- just need to watch your temperature
acccording to the manual the planter fan needs 6-7 gpm so that doesnt leave much for the lift and remotes
16 hours ago, acem said:
the hills are neat in the background of that flat land
1
19 hours ago, HydroTek said:
Then the return oil from the factory valve stack is "unfiltered" also -- LoL
Do the mod and don't over think it.
I have done this mod many times for customers -- Also have a couple out there with variable flow to run a hydraulic motor from that same port -- and the controls are inside the cab -- pretty slick setup
could you run a 8 row air planter with this setup without heating the oil too much?
10 hours ago, Matt Kirsch said:
This thread says there's an inch to spare. Just never get in the mud with it.
thanks!!
set on 36 in rows, will they fit? I put them on a 4840 and now it runs 21mph in road gear. It wouldn't hurt to speed the 1586 up and having 1rst high faster would be good
Auto steer ideas
in General Chat
Posted
My deere dealer is checking to see if they have a atu 300 mount for my 1586 with tilt steering. He said they did for a non tilt
