Big Steve
Calendar
Everything posted by Big Steve
You can get 6 different wheel setting with the rims in the picture if not more. 1 center dish in 2. Center dish out 3. Rim bracket inside center. 4. Rim bracket outside center. 5. Rim switch to other side bracket outside center. 6. Rim switch to other side bracket inside center.
Hydraulic clutch packs are meant to be shifted hard and fast which is what electric does . If you ease it in it Will slip the clutch pack and shorten it's life.
The engine is out of a 915 combine can tell by the hydro and pulley set up and radiator and oil cooler. The fuel filters are not an IH set up
It's a replacement Lucas from Springfield Reman
Steiner tractor Parts should have the kit you need
The top cover on the speed transmission needs to be rebuilt or the linkage or both . There wasn't a lot of adjustment built in for wear.
86series top cover will fit on 06 ,56, and 66 series rear frame . If the 3point came up to far it breaks out the top cover so it probably got replaced
What size tires is he running? 18.4 38 I would be in direct first
This is a dry sleeved engine should be able to overhaul it . But if you want a different engine 560,706,806 ,756,856 would fit. Engine numbers would be c263,c291 ,and c301.
Get yourself a set of angle wrenches great for hyd lines ,carberators, adjusting timing,and any place you can't in to turn a wrench. Harbor freight has a set 3/8 to 11/4 I got a set of standard and metric.
3/4 Reidi rod cut to the length for the amount of weights you want to put on.
Scale Models is still making toys 1/16 ,1/8 and pedals. There are still in Dyersville Iowa can I ask why you need them ? I may be able to help you.
Your 7120 will run the planterjust fine if you set your flow control properly. Put a pressure gauge in the motor supply line you have to keep the pressure under 2000 psi or you will lock the flow out of the pump where you have it set at . I have set a lot of Deere planters on Magum tractors when I worked at the dealership send me a PM if you more information.
If memory serves me right the first and maybe the second 407 blocks didn't have enough water jacket on the right side to cool a turbocharged tractor it would crack the sleeve. This happened on the 1256 you can tell the early blocks on the right side it followed the curve of the sleeve. The later blocks were smooth on the right side and I thought they used those blocks up on the 856.
Battery wire connection on the switch will lose its connection at the switch . It is not the voltage regulator it only job is to keep the voltage between 13.8 and 14.2 .
Reverse is half the speed of forward . The springs on the hydro are getting weak the load can overpower the spring and return the shach plate back to neutral .The hydro linkage should be rebuilt but you can put a 1/4bolt n the reverse slot so you can over ride the load with the hydro lever.
You may have the splines on the iptogear going bad. Does the remotes work Without making noise? Do You have power brakes and TA if you do they use the same hydraulic pump.
Your check valve on number 1 is not holding. Number 1 has priority over the other valves and isn't getting signal to the pump to engage.
Delivering new IH tractors on rollbacks in the 1970's
Big Steve replied to Matt Kirsch's topic in Technical IH Talk
Was working at a IH dealership in the late 70s hauled a 4100 with a cab clutch was out on a 1600 single axle rollback scary 40 miles back to dealership. The dealership abusedthat delivery truck but it took the punishment -
My grandpa was a Ford mechanic and I got his Ford manual that has all the flat head engines in it including the Lincoln v12
I think a v12 had 291cubic inches
I would use IH corn head gearbox grease.
With Striker782 on the intravance is bad excessive exhaust temperature and no power.
Corn on top of tractor cab.
