1586 Jeff
Everything posted by 1586 Jeff
  1. WHAT?!?!??? ESTATE Auction?!?!?!? Say that it is not so......
  2. My personal opinion is that some people think that it is cool. Myself, I find that to be quite uncomfortable to try to drive that way.
  3. Tony, I am pulling for your friend Eddie. Jeff
  4. Jeff, Talk to a heavy towing company as they pull axles on a regular basis. It might just be cheaper to hire them to pull the axle than to buy the tool for the single use. There are pliers made specifically for removing those split axle cones. One jaw is pointed to spread the cone for removal. Other Jeff.
  5. Insufficient water consumption and excessive texting?
  6. I too had to add a power feed to this plug on my 1586 to power my 6601 combine. I put an inline fuse on it as well as running the wire inside some plastic tubing for protection against shorting out.
  7. Rusty, I am pulling for your wife, your family, and yourself. Good luck! Jeff
  8. No camelback on this one Andy.....
  9. I am pulling for her Jake!! May she get the best possible outcome for HER wellbeing.
  10. Yes, it is a 2 Valve. The fuel pump runs and makes good pressure, but there is a restriction between the fuel filter and the fuel rail. That is why the fuel pressure regulator is getting checked out tomorrow, it is between the fuel filter and the fuel rail.
  11. There IS a filter between the fuel pump and the engine. That was the first thing that was changed. Further testing shows 35psi idle & 40psi WOT between the fuel pump and the fuel filter, but only 23-25psi at the fuel rail. I have already decided that it is getting a new fuel pressure regulator tomorrow. It is raining here now, otherwise it would already be installed. Thank you!!
  12. My 2004 F250 has started running poorly, it will barely move under its own power. I limped it to a local mechanic who diagnosed a bad fuel pump. He replaced the fuel only to still have low fuel pressure. A second replacement pump was installed on the chance that the first one was defective. I have not been able to locate a “fuel pump driver module” on this particular truck. Does anybody have any suggestions? Thank you!
  13. Aaron, I shall keep you and your family in my thoughts. I am pulling for your dad. Jeff
  14. He should use his sister-in-laws......
  15. There is a HUGE amount of truth to that!!!!
  16. Art, you have just won the Internet for today!!!!!
  17. Drilling a hard drive is a quick and easy way to render it mechanically inoperative. It would seem that a large electromagnetic field would do the trick to, say from a scrapyard magnet.
  18. 1586 Jeff
    Auger:
    That is an absolutely GORGEOUS SuperLiner!!!!!! Are you certain that it is a 1978? The air tanks and hood suggest that it is a decade newer. Is the steering box mounted to the frame rail, or the front axle?
  19. Were those early Model 12s? The reason that I ask is because the Model 12 that we had was equipped with inside the cab starting controls. Presumably this was a later model machine, but I cannot tell you what the serial number was and it is now gone.
