RAH
381 profile views
RAH's Achievements
Karl does a great job!
Those look really nice!! Someone spent a whole bunch of time on the lathe, or are they aftermarket ones?
Chrome moly cage? Old one mild steel?
Will have to change front hub and damper from truck engine to the one from the 4386. They are different and truck one will not work with the front mount hydraulic pump bracket.
Yes truck covers front and rear.
Atlas tractor could sell you whatever you would want for constant mesh gears.
That definitely makes for a bad day. On the bright side, an M would never let you down like that.
- 15 replies
- 12
Be sure you have correct head gasket. Oil passage is different from an early one to a late one. My guess is there is no oil getting to top.
766 with 360D oil cooler wanted-mission impossible!
RAH replied to Snowmad's topic in Technical IH Talk
If the truck one has the coolant filter as part of the cooler, the frame is in the way of the filter. I don’t remember if it is just a little or a bunch. Hope this helps. -
Google “Smith Brothers”. They make whatever you would like for pushrods and are very economical.
I’ve always seen them as a foot switch on the floor
Yes have done that. It works well
FIRST IH 1066 UP FOR AUCTION NOW SER #7101..IN UNREAL ORIGINAL CONDITION
RAH replied to Rhino2b's topic in Technical IH Talk
86,100 sold is what I see -
Ed, we have had that happen in our “big” M engine before. That block would have been a 400 or 450 block. Was ripping the center main right out of block. Had not heard that from stock engines before, but very interesting information!
