kitz
    30
Everything posted by kitz
  1. kitz
    1949 md
    thinking about taking a 49 md that's been left in the woods for a while and was wondering if anyone could tell me what these letters on serial number mean I believe it is a 1949 FDBK 206335 thanks
  2. kitz
    valve adjustment
    Howdy I have a c200 gas engine in a 574 that I rebuilt this past spring getting ready to change the oil , adjust valves and retorque head for 1st time since. I assume I should do all that with engine warm is that right? thanks
  3. kitz
    valve adjustment
    Thanks I figured so but I know when the engine was assembled it would have been cold
  4. kitz
    120 sickle mower
    Hi I have a 120 sickle mower it has a plate with notches in it that supports the back of the knives mine is broke would anyone know where I can get a replacement ive looked at a lot of sites but cant seem to find it thanks
  5. kitz
    120 sickle mower
    Thanks for the replies
  6. kitz
    120 sickle mower
    here is a pic of what I have but it sounds like I this is what I have if you can see it ok but I guess I will get the individual pcs thanks
  7. kitz
    120 sickle mower
    it is a 7 foot mower the plate I need is as long as the knife
  8. kitz
    120 sickle mower
    yes full length wear plates cant seem to find one
  9. kitz
    IH 444 Tractor fuel pump
    Check your float real well ive had problems with it binding on side of carb
  10. kitz
    c200 manifold
    Hi I have a 574 with a c200 gas engine and a underslung exhaust anyone have a vertical manifold they would want to trade tia
  11. kitz
    574 govenor
    would anybody know where I can get a governor for a c200 gas engine thanks
  12. kitz
    clutch disc
    Hi I have a 574 I am putting a clutch disc in. What side is flywheel side thanks
  13. kitz
    424 hyd control valve
    http://www.messicks.com/cas/61681?sectionId=57241&diagramId=61681_702391 would anyone know what size fitting number 1 in picture is I need to install a 90 here for aux valve tia
  14. kitz
    C-200 ih engine
    where did you get a rebuild kit
  15. kitz
    c200 gas rebuild
    needing to overhaul my 574 gas c200 engine where can I get a decent overhaul kit thanks rick
  16. kitz
    How far would you drive a tractor home
    My older brother drove a 666 220 miles to a new residence
  17. kitz
    424 diff lock
    I got it finally just what Bernard said. it was filled with gunk thru the years it just needed some soaking. then pull bull pinion with cage at same time then remove bearing race off cage to pull the bull pinion out to get to the seal. you would have thought they could have figured out something easier to replace that seal. it was easy but a lot of work for a 7.00 dollar seal
  18. kitz
    424 diff lock
    would anyone know how to get the diff lock apart so I can get bearing cage out. the book says theres a snap ring on the end but I don't see anything close thanks
  19. kitz
    424 diff lock
    ive tried to get it off but bull pinion gear wont come out of differencial
  20. kitz
    574 mcv valve
    Hi all I Have a 574 gas tractor with loader.When I turn on the pto it turns real slow, the mcv whines and my trans light comes on. I have set the plunger changed fluid with no luck anyone have a suggestion. I'm planning on putting in a new clutch pack but I feel it might be something else. Thanks
  21. kitz
    574 loader valve
    Yes it would be off pb I wasn't sure if I could just plug or not thanks
  22. kitz
    574 loader valve
    Hello I have a 574 with a 2050 loader. I want to take it off to pull engine for rebuild. the control valve is feed from the remote control valve can I just plug that off for loader removal or do I need to connect the feed to the return line. it is connected with flare fittings thanks in advance
