b&c farms
    118
Everything posted by b&c farms
  1. I just put a continuous duty solenoid on just the field lights on my 560 years ago never had a problem since then
  2. b&c farms
    IH radiators
    on my equipment if the radiators leak bad I just have them recored not cheap but if the first one lasted 30 to 40 years I hope the recore will last that long to most new ones are not going to last as long as the original one they are just made cheaper
  3. it is coming out the breather tube the tube comes out of the rocker arm cover or valve cover this engine ran great during harvest never got warm that is what is scaring me normally I always put everything in the shed at night because of some vandalism I had last year I left the combine in the field overnight just once now i'm scared someone did something to it
  4. what would cause a 466 to blow oil out of the breather tube after an oil change it runs fine has plenty of power I just changed oil and was filling with fuel when I noticed oil running out of the breather tube
  5. my vertical tube on my unloading auger went to heck so to get finished I just combined with it out because I could not get it to swing back in we took the horizontal auger off so we could replace the vertical tube now we got the tube in and the elbow on and it will not swing in got power to the coils you can hear the pump deadhead when you try swing it in or out it will swing in if you change the hoses around on the cylinder in the grain tank what am I overlooking
  6. b&c farms
    auger tube
    has anybody tried the upright auger tube from Worthington salvage for a 1660 combine part# 192830c92 was just wondering if they fit just like oem or do you have to modify it to fit the one from case IH is 1100 dollars and Worthington is 500 dollars big price difference I just want to bolt it in and not spend a bunch of time trying to make something kinda fit
  7. is your fuel tank vent open sounds like it creates a vacuum and starves it for fuel
  8. used to work on them a lot 4-53 6v71 they would neve blow just started to leak oil
  9. prayers sent hope everything goes good and a speedy recovery
  10. b&c farms
    1660 brakes
    how good are the brakes on a 1660 combine mine have good pedal but don't hold the combine from rolling downhill they act like they don't have any disc inside if you have it in second gear and try to stop it it does not have any effect on the hydro at all not sure where I should start looking I've run it this way for a few years but now my daughter is going to combine this year because of medical issues I have and just want to make sure that it is safe for her thank you for your help
  11. I have used tempo in the liquid form works really good on spiders crickets not sure what else it kills got rid of the label safe to use around the house and pets
  12. this is a very good forum everybody here is willing to help you out no matter what only one person on here wants to make everybody else feel stupid I went another forum to try and get some answers still waiting for the answers 8 months later this is a great site
  13. b&c farms
    allis 9745
    working on my brothers 9745 ac pressure is 40 low side and 240 on high side I can get the compressor to run if I bypass the relay by the fan and it will cool also can get the fan to run in front to run doing the same thing replaced the relay did not help replaced the thermostat and knob in the cab could not hardly turn the thermostat with a pliers and they broke the knob got all that done and it still will not kick on check the grounds for everything there and got grounds don't know where to check next not very familiar with an allis thank you guys for any help
  14. b&c farms
    Plow parts
    you can try shoup ind they carry a lot of stuff like that
  15. big problem is the justice system they will put this sob in jail he will appeal the verdict his name will be said over and over so nobody will every forget the sob he should be called the shooter and thats it do not make him famous for what he did they show him on tv for ten minutes the victims do not get mentioned i'm talking from experience guy was trying to steal my car I confronted him I got shot went to trail and I was picking on this poor child found out it was his birthday and just felt like blasting somebody won an appeal got out of jail killed his girlfriend went back to jail now out own parole if there is no doubt that they did the crime there should not be wasted time on them I hear how something is wrong with them that they did this terriblecrime so we spend all kinds of money so we can make sure they are fit to stand trial bs there is something wrong with them punish them how they hurt there victims
  16. should be a nhc engine there will be some numbers after that that will tell you all the specs of that engine I don't know what you mean when you say it is dead does it crank have spark the nhc was one of the better engines that onan made I was a dealer for them years ago the big problem they had with was the coil and the starter otherwise they were a good air cooled engine
  17. I got mine I think from fehr upholstery I was very good quality fit nice to
  18. been kinda dry here we got .30 rain last night thats about all we get anymore seems like about .25 to .30 of rain would be very nice to catch a rain hard to believe this spring we had 4foot of water on the field and now they are running the pivot
  19. you have ever right to be proud of him you brought him up right shows he takes a lot pride in his workmanship very hard to find that in todays world. I always kind of enjoyed finding problems when other techs could not find but that was many years ago now I just open the hood put in washer fluid and then close the hood got lost around that stuff
  20. went to look at it when it was in Omaha very impressive work very big would have liked to see it working in its day
  21. I used to run a sprayer for years and sprayed a heck of a lot of roundup still spray some today just for myself never hurt anybody that I saw just like everything else use the recommended rates and its fine
  22. what do the expansion tanks look like for the 66 series and how do they fit
  23. b&c farms
    9745 agco
    trying to help my brother out while he has some medical issues the pto stopped working on his agco 9745 found that the wires fell off the switch I figured the red wire is power goes to the + terminal just would like someone to tell me where the green and yellow wire goes to on the switch there is a P and a F on the switch I just don't want to hook them up wrong and burn something up thank you guys for all your help
  24. b&c farms
    trimble gps
    can I use the receiver AG15 L1 on a CFX750 I have this one in my toolbox and would like to put it on my planting tractor the one that came with the 750 is a AG25 GNSS I was kind of thinking it would be great if it would work the dealer I bought the kit from had know idea if it would work or not
