farmeracb
    158
About farmeracb
  • Birthday 05/23/1983
    Sparta, IL
  1. M, it does have the large cylinders, i will update my post as to not wreck this one.
  2. I agree. When i am running the T14 and the right track clutch slips and the engine will only hit on 3 and the blade leaks down too fast... I dream of what you accomplished with your rebuild. Then i check the bank acct, clean the spark plug, and turn right. Great job.
  3. Chris, im no expert and learning as i go myself. But as you don't have any replies , i will suggest yes by the book adjustment of the clutches and brakes will make a difference. When running my 14, i will pull a clutch handle in preparation to stomp a brake pedal to get turned. It is no dainty process, and after first few days i was elbow and leg sore
  4. Gary, Great pictures. There is something about a persons smile in an old car, not to mention there is always a story to come during the ride! I love that part. I put together a model A coupe affectionately known as "buckets", well, cause that's how I got it I just got it out yesterday and went by and took a lap around the country block with my grandmother. We both needed out of the house after the winter! I too am in short supply on the seat ordeal. I finally got the john deere combine seat cut of the original seat support and all of the pieces put back together for it to be how it is supp
  5. This post has something I have been watching for, for quite a while. 1939 H 36" rear shoes. I guess all the early ones had 36" but never see any of them anymore. Anyone got a spare set? Adam Adam, The rim has a split ring that is on the outside of the 38" tires. Gary Oh I see. My parts manual shows several rear rim options, all split rings in 36" diameter for tractor serial number FBH 501 to 1226. No other serial number notes are made for any other size. I always wanted a set just for the idea of something different on the '39 Don't mean to hijack threads. If anyone wants to talk abou
  6. This post has something I have been watching for, for quite a while. 1939 H 36" rear shoes. I guess all the early ones had 36" but never see any of them anymore. Anyone got a spare set? Adam Adam, The rim has a split ring that is on the outside of the 38" tires. Gary Oh I see. My parts manual shows several rear rim options, all split rings in 36" diameter for tractor serial number FBH 501 to 1226. No other serial number notes are made for any other size. I always wanted a set just for the idea of something different on the '39 Don't mean to hijack threads. If anyone wants to talk abou
  7. This post has something I have been watching for, for quite a while. 1939 H 36" rear shoes. I guess all the early ones had 36" but never see any of them anymore. Anyone got a spare set? Adam
