Torque
Calendar
Everything posted by Torque
Read online to back out spring and set idle 50 rpm low of what you want and then turn in bumper to raise rpm. Is this the correct procedure? Adjusted this a few years ago to stop surging but it is back to it, maybe something is worn out?
Dimple in.
- 1 reply
- 1
There is a big 1000, I have one, might be for sale...
The center section is an Eaton H110. I do not know who made them, GM used them in army trucks from about 1939 on and in commercial 1 1/2 ton trucks. Up to 1979 they were still used in some motor home chassis. Army trucks were 6.17 or 6.72 ratio, I think Elwood used a commercial truck ratio. The steering knuckles are army truck and the planetaries were designed and built by Spicer and adapted (by them I assume) to the army truck axle. The army truck always used Bendix steering joints but the Elwood (at least the one I had apart) had the much improved Rzeppa joints, may have been part of the Spicer modification.
I think all of them with cast centers had 40" tires so H&M rims will not fit and the axles on them were 2 5/8" so 2 1/2" H wheels will not fit. If you were really motivated, you might get 2 3/4" M wheels to fit with some bushings.
Just so everyone understands, there were several changes to the speed transmission on the 50 series. The one that caused the most problems was the fine-tooth clutch packs. In a planetary tranny there is no side pressure, and the clutch packs always stay centered in the drum so the clutch plate teeth last very well. Unfortunately, IH used this same shape teeth on the clutch plates in a counter shafted tranny. The clearance between the shaft and the clutch drum is always pushed to the outside causing the hub to move in the clutch plates the amount of the clearance every revolution of the shaft, and this wears out the teeth. The fix was to make the teeth coarser and change the shape to one similar to an internal gear (think 400 series oil pump gears) so when the hub moves in the clutch plates it does not wear them out. Another change was to the high drive gears. For some reason IH used a fine-tooth gear (gear teeth) on the high drive/driven gears when all the others were heavier coarse toothed gears. These gears could fail under heavy load when the splines on the countershaft would get loose letting the countershaft gear run a little crooked. The fix to the countershaft was to go to keyed and pressed on countershaft gears. Problem is IH planned to change all this stuff at the same time, and the full update is to change the drive gears, clutches, driven gears, all countershaft gears and shaft. This was very expensive, so they came out with modified drive gears for the coarse updated clutch packs that still used the fine gear teeth, so you didn't need to change all that stuff. This is what the aftermarket sells. None of the 50 series ever came from the factory with these updated parts, the changeover serial # is after the last production tractor came off the line. Any tractor with them was dealer installed.
They are probably CaseIH shovels, they are junk. I have lost 40-50 of them, the dealer replaced them for a while then said no more, said I was putting them too tight. I started putting them on with a 3/8" ratchet, they still break and fall off.
Some start easily at that temp some not, depends on how good the compression is. You can put a can of ether on it if your dealer has any there. Procedure for ether use: turn key on, push ether button 2 seconds. Open throttle half way, start cranking, every 3 second of cranking quickly tap the ether button again, it will fire up, pull throttle to idle. Tranny will be slow to engage with cold oil, just got to wait when you let the clutch out.
It will 100% tip over, been there done that. No damage, just thrilling. Four weights off and was fine.
Ii bought this one and like it. 118583 Brown seat cushion set (triplertractors.com)
They are available from CaseIH or were a couple years ago. Put a set on a 350, only the 450 set is available, but you just shorten them for the 350.
The bell seals are the same as the M135/M211 6x6 army trucks built by General Motors.
- 17 replies
- 1
Miss spoke, the army trucks used Bendix joints, they have 4 balls between ears for steering. The one Elwood I had apart had rezeppa joints, they have a bell with grooves for the balls (6 I think) and a smaller internal driver with grooves to match.
- 17 replies
GM never used that axle as a steering axle except in army trucks and they were never planetary final drive, so no, not the whole assembly. The planetary finals was a Spicer conversion and I have seen them on non steering industrial equipment and the Elwood. The center section is the same as the army trucks except ratio and I think the steering knuckle is the same also but the axle and spindle are different for the planetary. The Elwood uses U-joints and the army truck axles had rezepa joints for steering.
- 17 replies
The Elwood differential is an Eaton H110. GM used it from 1941 (army trucks) all the way to 1979 (motor homes) and in 1 1/2 ton trucks, so parts are available surplus or truck shops.
- 17 replies
I did my Magnum 215 last fall. It is a pain, I heated the boss on the axle red then used a 4X rivet gun (about 4 times a muffler gun). On mine the bushings were loose on those pins. Cleaned the rust off and they slid nice. Never seize the crap out of them when you go back.
There are a lot of running changes to the 466 but the "C" was just the inline MW pump. I put a roller cam in my 5488, went to the truck junkyard and got the cam and lifters out of a DT530. When I got them home I realized the cam is reverse ground. In the new style engine they run one more idler gear. Glad I compared them side by side because they look identical and I would have spent a lot of time trying to figure out why it would not run.
Don't know what was going on with that tractor but I put the complete update in my 5488, 44 tooth drive gears, countershaft and all. Did not change the speeds at all, it couldn't have, the ratios are the same.
The 5088 and 5288 have a much faster ratio planetary than the 5488.
You do not have the complete update to the speed transmission because you clearly still have the 55 tooth high drive gear, but it may have the coarse clutch plate splines which is what you need. The complete update changed the high drive gear to a coarse 44 tooth gear that replaced the 55 tooth gear for greater strength. This required changing the counter shaft gear and output gear (high drive) to match. The problem is they changed to the pressed counter shaft from the splined one at the same time so you can't just change the gear on the counter shaft to match as they never made the coarse tooth countershaft gear that was splined so you have to change all the countershaft gears. 88series restorer said they changed the high drive ratio when they went to the 44 tooth gear, this is not true, the ratio is the same. The original setup had a 55 tooth driving the counter shaft and a 55 tooth output gear for a 1 to 1 ratio. The coarse tooth setup was the same but it had a 44 tooth drive and 44 tooth output so still 1 to 1 ratio, the tooth count on the countershaft has no affect on the ratio.
I have a mounting bracket for the UD plus in a 21-23 series combine, you can have it. The UD plus works OK, much of it is like a pro 600 except not color.
If you have the flapper style the fix is to drill and tap the plstic for a screw to push on the flapper, adjust the screw so it almost trips the switch. Never had it fail after this mod.
Don't know where you are but Colfax tractor at Colfax Iowa had a 995 I bought the turbo setup off of for my 895. The engine had water down the exhaust so was stuck, the only reason they would sell parts off of it. I am sure it is still there and the head should be good.
2366 Combine - Struggling in Soybean Harvest
Torque replied to SleepyKnoll's topic in Technical IH Talk
Check to make sure the transport vanes in the cage are good. If they are wiped out it will act like that, BTDT. 2144 here, 30' 1020, 50bu beans @ 5 mph, 70 bu @ 3.5 mph. -
Probably the HVAC controller, they are not available. You can send them in with $400 and they will diagnose them and if they are repairable the cost is $1200-$3000 but they allow your $400 against that. So... salvage yard.
