Well I aquired another project. looked interesting to me and I wanted to save itpost-113851-0-21775600-1454690617_thumb.
I paid $500 for it, does not run but turned over with battery and hand crank
I am assuming that I will drain all fluid and start over to be safe
does anyone out here have any experience with restoring one of these units???
post-113851-0-20003000-1454690717_thumb.
post-113851-0-15818400-1454690787_thumb.
post-113851-0-39427800-1454690822_thumb.
That's a nice straight power unit. I hope you can get it running easily. Any idea what it was used to power? I would love to find one.
nice u4. I have one under a tarp that turns over but I haven't got it running just like yours. I thought it would be cool to have but now that I have it I don't know what I am going to do with it once it runs
They are the same as an H or w4 engine so theres nothing special about restoring it
Good luck with it when you get it running
This particular unit was being used for irrigation purposes. Until fuel started to go out of control about 7 years ago. I already removed the centrifugal pump. I think I would like to put on belt pulley but not sure how fast it turns yet.
Does anyone know serial number codes to Power units? UBH 16849
Looks like 1948
12813893_1390844324275882_55337260855194934714_1390847527608895_725020158794273012832363_1390847804275534_83009738810667
If you are referring to belt pulley RPM, I don't think it is crank speed? I did the math a couple of times but keep forgetting it. Somebody in the know can post on that one.
My experience with power units is only with the larger 9 and 18 diesels, but they seem to run a specific load speed according to intended use. Some are faster, some slower than stock. How does the throttle work on that one? Mine had off, idle, run.
They are usually in great condition compared to a tractor engine.
that power unit looks like it only has a clutch on the back of it so it would be crank speed. my U4 has a gearbox on the back of it
That's what I was afraid of, I may have to find a gear box that fits. I wander if an H or W4 unit might work??
hillman can you post a picture of your gear box
Thanks!
post-36945-0-55314400-1458000563_thumb.j
I don't know what you want to drive and at what speed but its not that hard to reduce the speed using a larger driven pulley
Is that an actual gear box?
I want to install a typical belt pulley for a saw
its a transmission which is a gearbox
A belt pulley attachment from an H or W4 is of no use to you. they are transmission driven.
So I am starting this U4 project
Here's the before
Stripping it down tonight
Gonna need a new one of these
Radiator looks good
I think I'm going to change to a distributer
Doing some electrolisis
Old school
I would use one of the power units to run my Hobart Bros. welder head
[300 amp DC] the 16 hp vanguard does ok with  3/32 rod ,,struggles with 1/8''
