redstroke
1256 Cummins Conversion
Ed when you talked about a repower in a 650 it brought back some good memories .Back 1978when I was in FFA my dad had a 650 D. that cracked a head and we could not find a reasonable replacement so as a project we put a GMC truck V6 in it .
What a great tractor 200HP. My father past away in FEB. 2013 My oldest brother restored the tractor last winter.it brings a tear just to think about it today .
I forget what your name is but dont you live in Onsted Michigan? Your brother or you restored a really nice Mccormick Deering 10-20 with "duals"
I talked to either you or your brother about this 650 at the Threshers show this past year.
Chris
Ive got it!! I remember I talked to Bruce Shultz about the 650. My dad works at Archbold Equipment (formerly Dans Farm Supply)
Hes Rich Glinski
Im Chris Glinski
Chris
That's a fantastic engine I love the 6bt pretty cool coversion!
Hey Chris
Bruce is my oldest brother .He has restore a bunch of old classic tractors and the 10-20 was his wifes birthday present .
He has the restored original AC model E that my grand father bought new .
It was the first rubber tired tractor in the county .
Nice to have still have in the family.
If you get to Onsted go West on Stephenson Rd. 4th drive North side is mine 7th is Bruce's
here are a couple of works in progress, tractors of customers doing repowers
What is in the 560 Ed? I am not as good at telling engines as most, is that a 360?
yes the 400 and the 560 are Dt 360's
the M is a 5.9.
going to see what else we have pics of next couple of days
the M is a 5.9.
What machine is the 560's 360 from?
As far as I know it is a truck engine.
I am sure they used a shoe horn to put it in there. I have never seen the tractor in person. I know they used the truck front cover and modified the lower water neck to be above the frame rail with some hi tech epoxy and ingenuity. We supplied the rear plate and the flywheel clutch etc. It is some where in the Little Chutes Wi area. They are putting a TA in it this winter. We supplied that as well, it will be interesting to see how it holds. Beefed up unit and if they don't get into the heavy weight class's it should be ok. Pretty much a stock truck motor although they are pretty potent. often overlooked when guys repower but will give a 400 series a pretty good run for the money. and they fit in a lot easier in many places like 06 and 56 series
Wouldn't it be fun to hang a 5 X plow on there and go to a JD plow day!
ed
Exhaust mock up
2F6B6932-E006-4747-B808-520A8928B875_zps
43FAB14C-9A02-499D-9CE4-2ABAE12FF06E_zps
F3844F98-9A71-490A-BF1A-2ABD52BEF9A4_zps
Charged Air Pipe
00097119-0E08-4173-9FDB-82F2B9C8978D_zps
Test on battery tray conversion to group 31
47842BE5-9604-4022-88B7-9C00786CC170_zps
Did get it fired up. Having a hard time trying to make the factory air filter to work. Cant make this line up. Still looking for a way to make this work.
AAC235B4-B3FC-41C3-BE0E-779CEDAF90C1_zps
This may be something you have already looked into but have you looked at Donaldson filter housings? My thoughts are that they might make something that will fit in the factory location with a different outlet for the filter housing getting you more room to hook up to your turbo. I looked through their stuff when I did a new intake on the SD33T in the my Scout and was impressed with the options they have in different CFM ratings. Just an idea. What is the factory engine supposed to flow vs. the Cummins?
Any of you guys that have done these on red tractors find a way to run the tach? I did a Moline and was planning to run the tack off the alternator. I have not found a good tack to use yet. wondering where to find a electric tack with a reasonable rpm range. mm used a tack probably close in size.
luke
Diesel equipment company greensboro nc but there may be a local branch close to you it is a little smaller than I h one in diameter but only about an inch needs acc wire from alt
Exhaust mock up
Charged Air Pipe
Rubber 90 degree turbo hose of 1987 IH Smodel truck ,model 1954 with DT466 then a exhaust coupler to stock hose 90 off IH gasser.check Salvage yards,walk around look.
Well here are some more pics. Been a long winter project but turned out decent I think. Will be running manure pump shortly.
Narrowing up battery cover.
5B78862D-21F9-4F9C-950A-745F76A25BC8_zps
25CFD1A4-D548-4E02-B68B-94C08D4E640B_zps
Gauge pod mock up for murphy switches
6215D1E3-58E6-4064-92CE-8756CE2BA302_zps
Throttle cable mock up
1F09BA49-863D-445C-B7F0-6A9B5B3ECCE2_zps
EB64BFA3-F1F4-4F91-9AE6-8758DE2A3AE3_zps
Leds
E9DAFE1D-1C6E-4EE9-B89D-D6C8FE065296_zps
Gauge pod murphy switches for running pto pump all day long
B9FCE01B-308D-45F2-829B-E3D1B97507FC_zps
1E413425-66C4-4A65-8652-7670B4B1CF9F_zps
Tilt steering bushing
64F4E770-294D-4A9B-8C1D-E7E6F7A41AF0_zps
80884502-3FBA-4618-AAF1-5779995B9FFE_zps
5140 Air filter housing and upper rad hose setup. This was very hard to make all work and keep factory hood holes.
5ACBE41F-CB5A-4D5E-AF80-AB8876B2E0C7_zps
823D715C-A3EA-4BB1-A422-52FD82F7566F_zps
Hooked up the heater grids. Also have block heater.
CB9E1438-76E5-4F8A-9A45-64B1176DBB06_zps
EDIT:
Cummins pump is .5 to 1 international tach is 2 to 1 so works just fine hooking the two up with international cable.
9BC05BD2-D4E2-4D39-BA91-C3C0B24A8DCC_zps
Tightest part of under hood compartment is the right side of hood to 3" air inlet tube from filter housing to turbo.
9B2960FE-1C6D-4215-B9B9-B401B139F96D_zps
Needed some bushings in steering.
DD6B927B-9F93-4B46-81EC-E58FDC5EA858_zps
Finished up and ready to get some work.
0E74AB29-8FDE-4C4B-958D-DA6215E7DABE_zps
56D032C0-C7EF-4FD7-B52B-B98370B94ED9_zps
Any inexpensive 1256 emblems? I cant find anything reasonable. I am fine with aftermarket as well.
Awesome job man.When you get the tach all figured out, would you share the parts list?Mine is all done except battery box needs neatened up.And I've got to build a wiring harness.Again, nice work.
You will love the less fuel consumption mine has trouble staying warm to the hammer mill I'm use ing the putting a acc tap off alt to run an electric diesel tack not original but cost effective it looks great good job
