852072
2072 Question
Did Cub Cadet ever make a 2072 with a manual transmission from the factory? Or is there any way of fitting one of a different model onto a 2072.
DOCTOR EVIL    0
Nope, they were ALL hydro's. The 3-spd gear drive rearend bolts right up to the frame but all the hydro linkages have to be removed, and the clutch & brake linkages added. And what would have to be done would depend on if you installed an Internal ot external brake GD rearend. Plus you'd need the clutch linkage. Drive shaft would be totally custom, the bigger CC's are 5-6 inches longer between the steering column and the seat.
The hydro charge pump powers your power steering & hydraulics so that would be gone unless you installed some other type of pump, And if you have individual brakes on each rear wheel they could be made to work but not sure how you would make up the linkage.
thanks i was just wandering cause im planning on turning one into a puller and i wan ted something thats was strongerr than the factory hydro
DOCTOR EVIL    0
Actually, from what I've read on Midwest Super Cub's forum the SGT's, (Super Garden Tractors) don't really make great pullers. The longer frame makes them harder to get the balance right. Unless your building something with a LOT of HP the shorter frames of the regular CC's seem to pull better, are just as strong, and are a LOT cheaper.
I'd hate to see you put a lot of work & money into making a 2072 puller and be disappointed.
