2+2 electrical question
2 replies to this topic
#1 Silver Dollar
Silver Dollar
    Newbie
  • Pip
  • 9 posts
Posted 29 March 2012 - 11:12 AM
I have a 3588 digital tachometer that is giving me problems. Original unit w/ rpm, exhaust temp, 1000 pto, & mph. Seems to be speratic, but at times it won't indicate the proper rpm, mph, etc. Sometimes it reads high, sometimes low, or it flutters up and down w/o changing the motor rpm or tractor speed.
I had a replacement tach unit so I switched it out. Same issues, so it looks like its in the wiring harness? Speed sensor under the seat was replaced a couple of years ago. Does anyone have suggestions or steps for trouble shooting this? I'd like to have this working correctly because its my planter tractor.
TIA, SilverDollar
#2 pete 23
pete 23
  • 3,411 posts
Posted 29 March 2012 - 11:39 AM
Disconnect the engine speed sensor and clean the connector contacts, remove sensor from clutch housing , clean end and then readjust it , turn in until it contacts flywheel ring gear, then back out half to three quarters turn. There is also a inline fuse down by the other fuses, clean those connectors. On the back side of the data center is a pull out module, clean those contacts with a pencil eraser. Check and clean your ground cable on right front cab mount. Then just throw up your hands.
#3 pete 23
pete 23
  • 3,411 posts
