MarkOb
Engine nomenclature
11 posts in this topic
Over the years IHC has used a lot of different nomenclature to identify their different engines.
I know that the 6.9/7.3L diesel has had several different names depending upon the application. At Ford they became the Powerstroke. At IHC they were called the T444 with several suffixes.
When the 6.0L started production they were still called the Powerstroke over at Ford.
What was the 6.0L called at IHC?
When Case/IH developed what became the Cummins B-series four and six cylinder engines, what were they called at Case/IH?
The "VT-365".
I was wondering if the VT-365 was the 6.0L.
Yep, and near as I can tell, the 6.4L PSD is now called "the MAXX-FORCE 7".
It sure helps to go the the International dealer for parts for a T444E rather than the Ford dealer for Powerstroke parts!
Yep, I've saved a boat-load of money buying parts at my local Navistar dealer for my '96 PSD in the last 16 yrs. My local Ford store wanted over $30 for the oil filter for it 16 years ago, My Navistar dealer charged $12, I get all my GPR's, CPS, fuel & oil filters there. I needed a thermostat last summer, Ford store wanted $60 including tax, Navistar dealer wasn't sure which one I needed, one was $12, other was $14. I ended up getting one at the other Ford strore for $28 including tax. I think my fan clutch is toast, I checked on line, the local Navistar parts guy said he could save me well over $100 but would have to see the old clutch to make sure I got the right one. When I replace it I'll see him first with my old clutch.
My local Farm & Fleet started carrying the Ford FL1995 oil filters a couple years ago for $10/each. I was surprised they weren't identicle to the Navistar filters. The fit, form, & function are identicle but the one filter has six bigger holes in the base plate and the other eight smaller holes.
It is pretty crazy over here in Elkhorn/Janesville. The Ford dealer in Elkhorn has oil filters for $17 now and NAPA is selling them for $3X. I couldn't believe that one! I'm guessing they want to get people back there to buy parts.
FYI the up pipe gaskets from Navistar are WAY cheaper and WAY better than the Ford ones. I am thinking about doing mine pretty soon. My fuel milage is starting to drop off and that is a pretty common cause. I am going to check a little more once things heat up.
Also, if you need fuel drain valve o rings I have a big bag full. I bought a 100 from McMaster-Carr for the price of a couple anywhere else.
When the killer cam position sensor let go on my '02 Super Duty, I was way out in the country at a customer's place...called Ford, as I wasn't sure if the warranty would still cover it or not. Service guy was very vague about the warranty, or whether it was actully the CPS or not, but they could tow it in-(20 mi.)-& maybe get to it Tuesday...(this being Thursday)...& a new CPS was $90...So, I hitched a ride home with my customer's "amigo" hired man, got in my service truck, buzzed up to International, got a CPS (same part #) for $30, buzzed out to the farm next morning & had her running in 5 min...6 mo. later, Ford announced the CPS recall...got the new supposedly bullet-proof one for free, but I still carry a spare... :rolleyes:
I'd be scared to try to do ANYTHING with my exh. manifolds, up pipes, etc. The manifolds & mounting studs are so rusty I'm afraid they would fall apart. I'm sure I'm loosing boost & MPG but I don't drive the old PSD much anymore. I'm sure I'd twist every stud off trying to remove any of the nuts.
I've never touched my oil cooler in 16 yrs & 300,000 miles. I'm waiting for that last flake of rust to fall off the outside and it start leaking. I'm looking forward to THAT job too.
The V-6 was first called the VT-275 and the V-8 the VT-365 (Don't ask me how they got those numbers as those aren't the displacements).
They became the Maxxforce 5 and 7.
6.0 liter = 366.1 cubic inch
6.9 liter = 421.1 cubic inch
7.3 liter = 445.5 cubic inch
