782 problems
driving me potty
6 replies to this topic
#1 ozfarm
ozfarm
  • 2,737 posts
Posted 13 January 2012 - 01:22 AM
sold a 782 out of the batch that came in from the USA, did predelivery on it, new points,new plugs, filter, kit thru carby etc, ran, mowed, despatched to buyer
is know deciding to stop every now and again, if it stops, it wont start , after a while, it will start
have replaced coil , getting ready to send over a new condensor
any ideas :blink:
"THE V8 HUNTER
Rural Wrecking
WA Division
Ozfarms Vintage Garden Tractors
and common garden variety genius
109 CubCadet SnowPlough(whisked out of my grasp by a cunning 696IH who exploited my weak point),682 CubCadet 782 CubCadet,,JD 140H3,JD112,JD110,660D,560D NF Fast Hitch,540 ploughTD9,,TD9B,150,Farmall Cub,Farmall Super A ,Farmall BN, Farmall C,2btm plough, Farmall 340,FH plough,,blade,Oliver 66 77 88 , Minneapolis Moline KTA ,Case DEX,LA,IHC 706
and other goodies too fascinating to mention
i gotta snowplough now......
#2 exSW
exSW
  • 2,405 posts
Posted 13 January 2012 - 12:13 PM
any ideas :blink:
I'd check the run circuit through the key right after it fails.I'd bet some type of heat induced break to the circuit.
66 706D NF FH,59 560D,54 TD-6(sold),Model 46 baler,Model 76 combine,Model 155 Spreader,Model 56 planter,100 FH mower,463 FH cult(2),782 Cub Cadet(2),682 INTERNATIONAL Cub Cadet,1650 cubcadet w/50A mower and 1A(?) rototiller,311 FH plows(3),FH subsoiler,Fast hitch carry-all,10'8" FH disk,FH post hole digger(needs ring gear),FH landside hitch(I think) and looking for more!
Member Brotherhood of Locomotive Engineer's and Trainmen Division 757
UT Martin '87
"Get there the firstis' with the mostis'"Nathan Bedford Forrest
Sire of:2011-2012 PA State FFA Association Sentinel (TLC)
Scars are Tattoos with better stories
#3 farmall57
farmall57
  • 672 posts
Posted 13 January 2012 - 01:19 PM
Might check for exhaust valve sticking. Some claim a little marvel mystery oil can help prevent it, IH Low Ash oil can help too, if available.
3788, 856, 666 w/F11, 240 w/Wagner backhoe, 4136 IH Skid Steer, IH-Hough 530 Payloader, 3850 Payloader, 350 Diesel utility, 300, M (2), H (2), Super C, 58 A110, 59 B160, 62 C120 4x4, 66 Scout, 68 Scout, 68 Travelall, 71 Loadstar 1600, 75 Loadstar 1700 4x4 w/Coleman axle, 71 1110 4x4, 73 1210 4x4 (3), 74 150 4x4, 74 Scout w/Chrysler 440, 78 Traveler, 76 Traveler, 80 Scout Diesel, 80 Terra Diesel, , 392 LPG Irrigation Engine, 84 F250 w/6.9 HyperMax Turbo, 2000 F350 PowerStroke, Cadets-60, 111, Cub Cadets-Original, 70, 100, 127, 1450. Literature collection too!
#4 Rainman882
Rainman882
  • 678 posts
Posted 13 January 2012 - 05:40 PM
Check fuel tank, gas line , gas filter.. carb blow out again ...Took me 3 tries on my 1811, but finally success! PWR
#5 ozfarm
ozfarm
  • 2,737 posts
Posted 13 January 2012 - 06:22 PM
rainman, have done that
im more inclined to go with exsw suggestion, as we had an issue with no power to coil, plug on wiring harness was the culprit
"THE V8 HUNTER
Rural Wrecking
WA Division
#6 exSW
exSW
  • 2,405 posts
Posted 13 January 2012 - 08:26 PM
It also could be in the PTO switch.Also a voltage drop shuts down the PTO first then later the engine mostly associated with a no charge condition.Brake interlock switch,take off the driveline cover to get at it and watch yer fangers.
UT Martin '87
#7 gonzo 1066
gonzo 1066
  • 7,084 posts
Posted 13 January 2012 - 10:32 PM
My older 782 did exactly the same thing, ran really well for quite a while then it would sputter and quit. Leave it sit for a while and it would start right up. I did points,condenser,plugs, wires etc. None of that helped. Finally I drained the fuel tank, there was a small piece of black rubber hose that apparently blocked off the fuel flow on occasion. Now it runs great..
"Rooster" 1066 puller tractor,
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered.Cub 1572 Diesel  CanAm 800
 Dodge Cummins truck 2013"Buckweet"yes its automatic transmission
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
