NewTD9B92
New Owner of a TD9 Crawler
39 posts in this topic
Well everyone I just bought a international TD-9 two days ago. I took some pics as i am trying to find the year of the baby. The serial number and model number below.
Model # = 9K3-B
serial # = 11519
I am waiting on the manuals to get more info on it but wondering if anyone can tell me something about it. Any info would help. I have many more pics on photopucket but the rules say not to link any. As far as i know everything runs but you do have to use starter fluid. No leaks on the cylinders but some around the hoses inside.
thanks,
Anthony
post-61336-0-98710900-1322706323_thumb.j
post-61336-0-70026200-1322706586_thumb.j
a couple of more pics
post-61336-0-68874500-1322706971_thumb.j
post-61336-0-42833500-1322707115_thumb.j
Some more of the tracks and rollers
post-61336-0-05486100-1322707724_thumb.j
post-61336-0-52487200-1322707736_thumb.j
Tracks sorry i missed this. Enough pics lol
post-61336-0-46847700-1322707795_thumb.j
It looks like you have a TD9 92 series. The serial no. and model tag is for the Drott Loader. The crawler tag should be in the area of the brake pedal, I can't remember which one.
Some one really did some work on the idler roller.
Welcome to the forum!
DWF
Yeah thanks, I was curious on if that is how it is suppose to look. It doesn't look natural.
I will look by the pedal and as i see there is a tag there and get the numbers. thanks everyone.
The top roller and sprocket ben work and if you need startor fuild your glow plug are not working
The SN tag and number you posted is that of the loader assembly. The loader frame was built by Drott corp in Wisconsin. As others have mentioned the IH crawler ID plate is down by the kicker panel. It looks like you have a TD9-92 series Drott loader made between about 1959 and 1962. It weighs about 21000 lbs with a GP bucket and counterweight. It is a manual shift transmission (non-powershift) and it is equipped with the direct start, turbocharged, 282 cu-in inline six diesel engine. It puts out somewhere between 66-71 hp at about 1800rpm (depending on turbo boost and injection pump setup). The machine is equipped with dry type steering clutches which can sieze if you leave them sit for a long period of time without use (plates will rust together). It's a strong machine and is capable of a lot of work, I have one very similar to it and have used it for years. The 150 Drott loader superseded the TD-92 series Drott loader in 1963. The manual shift version of the 150 was very similar to the earlier TD9-92. But a powershift transmission was an option on the 150 and that's the main difference between the two machines. There are also changes to the hood profile, the radiator and cooling fan setup, the front grille, the number of upper rollers, the spoked front idlers vs solid and some sheet metal variations. But for the most part the -92's and the TD9B's (150 in loader form) were pretty similar and share a lot of parts.
Err, I was looking,I could be wrong,but isn't that a TD9B? 1965 Model I think. according to these guys anyway http://tractors.wiki...al_TD-9B_series Don't know they're right,but serial number makes it a 44' or a TD9B
IH did sell a TD9B Drott loader in addition to the 150 loader at the same time. The TD9B Drott loader had the dozer chassis instead of the traditional loader chassis of the 150. The 150 track base was longer and used low profile grousers to aid skidding in pivot turns with a lot of weight in the bucket (in contrast to the TD9B's standard high profile dozer grousers). According to sawmill (an old member that used to frequent here with half a century+ of experience), he said the TD9B Drott loaders were popular for use in certain applications because of its increased manueverability due to the shorter track base. I think he said they were good at loading logs onto trucks and freight cars etc. Of course you do give something up by using a dozer chassis, probably less ultimate load capacity and less stability under certain circumstances due to the shorter track base and grousers that don't slip as easily during skid turns.
Anyway, the TD9B Drott loader looks almost identical at first glance to the TD9-92 series Drott loader. But there are certain tell tale signs that makes it easy to tell them apart. The main visual cue is the front radiator grille. The -92's had a pronounced bulge on the lower part of the grille. This was to accommodate the loader's relatively large hydraulic pump protruding forward. The later TD9B's (and 150 loader) had been redesigned so that the pump was fully contained inside the crawler body without the need for a bulge. The older -92's also had a hole in the radiator with the fan shaft going right through it (with the fan spinning in front of the radiator instead of behind it in the TD9B and 150). Pretty interesting when you see a big hole in the radiator and it's actually designed that way. If you look at the side profile picture TD9B2 posted, you can see the lower cowl bump indicative of a -92 series. The spoked front idlers also are peculiar to the -92's (TD9B/150 had solid idlers), although sometimes you'll see these two swapped out between older and newer machines because of parts interchangeability, which can throw off the identifying process if you're not aware of that possibility.
Thanks for clearing that up for me Drott-150
Now I know a little more than before
Welcome to RP,
If you look at your photo of the dash you can see the silver i.d. tag just above the left brake pedal and below the throttle. You'll need to perform a dumpster dive to be able to see it. This # will give us the info to provide the year on it. It's a 92 for sure and not a B. The year is good to know and you’ll be able to interchange many parts between 91, 92,150 andthe B's, just make sure you do your research first. As for the start up, you need to make sure your glow plugs are all working (use test light or hold your finger on each plug where the wire connects and feel for heat, as someone presses on the button). The plugs are a must on every first start up (45-60 second hold), no matter what the ambient temp is. I'm in Arizona and the glow plugs are required on summer start-ups, with ambient temp's well over 100 degrees. It's just the nature of this beast! After you reach working temps you should be able to restart without use of the glow plugs, as long as it hasn’t been shut down to long. If its been stored or hasn't been started for a long period, I typically give it about 3 notches on the throttle, turn it over for 2-3 seconds to prime the injectors, then glow plugs for 45 seconds, then fire. This seems to be the trick for Rex. One other important thing before shutting down when it's been worked is to let it idle for a bit and cool. This helps prevent cracking the head, which was more of a common issue on the 4 cylinders and good practice to perform with the 6 cylinders too. What are your plans with this machine and keep the pic’s coming? Good luck and keep us posted on your findings. Nick
Everyone thanks for the input. I am going out to my land and will get the ID number from the bottom. Here is the front radiator and pump
post-61336-0-43687700-1322876782_thumb.j
post-61336-0-38696300-1322876871_thumb.j
Glow plugs, a picture of a tube between the tracks on the left side, and the radiator
post-61336-0-88416700-1322877040_thumb.j
post-61336-0-76387100-1322877158_thumb.j
post-61336-0-47899400-1322877189_thumb.j
Pic next to my dually
post-61336-0-53206500-1322877557_thumb.j
post-61336-0-61213400-1322877593_thumb.j
ok went to the land and got the numbers which is below
TD92-1455
1965
So i guess it is a 1965
According to my info, from the Payline book, it would be a 1959. The 92 series came out in 59 and serial number 501 (which is the norm for IH) was the first and went through 2352 for 1959. By 1965 they were either a 150 loader or a TD9-B.
I had a TD9-92 like yours, SN706 and a TD9-B dozer SN 10855, I believe, I know it was a 1966. The 92 series with a Drott loader is still parked s few miles from here, I don't know why the owner doesn't part with it. It's been sitting out for years, so who knows what it's like now.
DWF
The Serial Plate is no doubt hard to read, but 1965 is the recommended high idle no load engine rpm.
I agree with DWF that it's a 1959 and Grabatire is also correct with 1965# being the max RPM. See below info.
TD9 92 series 1959-62 WT-11800lbs Doz-3700lbs Loader-19365lbs
501-1959
2353=1960
3895-1961
5099-1962 6501 end.
As for the tube between the tracks, can you give us a photo of the whole tube where it connects at each end?
As I'm sure you know that you have a couple leaks that need to be pressure washed to help i.d. the origin. While you’re in there and when you get your manuals, make sure to replace both the fuel filters too.
Also, looks like your missing your glow wiring harness, which explains the need for starting fluid. You should have a push button switch and glow meter on the dash to activate/shows activation of the glow plugs. The wiring harness is piggybacked from one plug to the next. See the diagram for proper wiring and read "checking for defective glow plugs" section. This should make starting much easier for you and the engine. I also included the glow plug operation as well. The attachements maybe on next post. Good luck and keep us posted.
Nick
post-9539-0-00971800-1323111023_thumb.jp
post-9539-0-20927200-1323111088_thumb.jp
Hey Guys,
Did they use glow plugs on earlier models as an opption or did't they exist yet.
My td9s start on gas and I wondered if they were ordered that way or if that was all there was in the mid 1950's.
Thank you,
Have a great day.
I don't know of any IH diesels that started directly on diesel until the TD6-62 and TD9-92. I believe they all used a gas start. I could be wrong, but I know I am correct on the 6 & 9 series.
DWF
Well It is time for me to sell this baby. If anyone is interested let me know. I am asking 2000.00 for it.
