M Diesel
IH construction equipment serial numbers & engine xrefs
I have what I believe is a 1941 T-9 BE 38 Eng. ID TCBM2293-T
And a
1946 Adams Motor Grader 311 w/TD-9 Eng. ID TDCBM3828-T AD 70-B w/ Oliver Model 80 Stranded EOA 35 transmission/finals
UPDATE:
FOUND Egn .CODES UDCBM 7395 11.28L (1944)
post-114211-0-23378800-1416564750_thumb.
post-114211-0-20372500-1416564455_thumb.
post-114211-0-40168000-1416564611_thumb.
post-114211-0-78118600-1418016935_thumb.
I have a Dresser 175C, S/N 4290004U004166.
I think it is a 1987 model; however, I have never found a chart or listing that shows it to be a '87. I have seen all the IH listings on this thread; however,
they only go up to early '80's.
Is there such a listing available?
Thanks
I bought a Dresser TD7G serial # 4410022K005016. I've been told it is 16th in the Korean production of this model. Does anyone know when it was made, or the year they first built these in Korea?
The TD7G was built in Korea and the US. The Korean serial series began with 5001 so you have the 16th produced. The US version began with 501. Yours is most likely a 1987 or 1988 model
Tom
I have a 530 Payloader that is Canadian (why it's in Colorado I don't know) built with a Cxx2179 serial number instead of the Uxx2179 (U for USA built) number. My questiion, was there both a Uxx2179 and a Cxx2179 machine? (2179 is not the actual number used for example only)
TD15 1958-61 150 series
WT-21860lbs Doz-4675lbs Loader-32650lbs
501-1958
577-1959
2456-1960
3501-1961 4000 end
TD15 1961-63 151 series
WT-22845lbs Doz-4675lbs Loader-33200
4001-1961
4680-1962 5236 end
TD15 1963-72 B series
WT-22350lbs Doz-5000lbs
6001-1963
7100-1964
8935-1965
20377-1966
21192-1967
22082-1968
22936-1969
25430-1970
25925-1971
26475-1972 26516 end
TD15 1972-96 C series
WT-24500lbs
501-1972
1130-1973
1849-1974
2750-1975
3322-1976
3621-1977
3960-1978
4516-1979
4901-1980
5196-1981
5701-1982
5892-1983
6100-1984
6172-1985
6526-1986 built until 1996
UK assembled TD-15C had separate serial numbering
501 - 1974
502 - 576 1975
577 - 697 1976
698 - 776 1977
777 - 823 1978
T & TD6 1940-56 [ TBK & TDBK ]
WT-6925lbs &7235lbs Loader-12910lbs
501-1940
4435-1941
8191-1942
9297-1943
9581-1944
10828-1945
12058-1946
14516-1947
17349-1948
21146-1949
24862-1950
27536-1951
31056-1052
33157-1953
35746-1954
37470-1955
38706-1956 38950 end
T & TD6 61 series 1956-59
WT-8375lbs & 8470lbs Doz-3400lbs Loader-13790lbs
38951-1956
39817-1957
40822-1958
41448-1959
T & TD6 62 series 1959-69
WT-8500lbs & 8697lbs Loader-14125lbs
501-1959
1063-1960
1629-1961
2056-1962
2404-1963
2758-1964
3177-1965
3631-1966
3991-1967
4221-1968
4424-1969
British built BTD-6 (50 HP update) BD-264 glow-plug diesel engine
2401 - 3461 1955
3462 - 4640 1956
4641 - 6462 1957
6463 - 7931 1958
7932 - 9943 1959
9944 - 12037 1960
12038 - 14491 1961
14492 - 16124 1962
16125 - 18075 1963
18076 - 19372 1964
19373 - 19706 1965
19707 - 19923 1966
19924 - 20137 1967
20138 - 20261 1968
20262 - 20413 1969
20414 - 20559 1970
20560 - 20644 1971
20645 - 20722 1972
20723 - 20857 1973
20858 - 20899 1974
20900 - 21033 1975
T4 T5 TD5 TC5 & TDC5 1959-64
WT-5767lbs & 5959lbs
501-1959
1345-1960
2215??-1961
n/a -1962
n/a -1963
n/a -1964
BTD5 1963-67
501-1963
511-1964
539-1964
564-1965
567-1966 667 end
DTD5 1961-62
500 series 1965-69
WT-7970lbs Doz.-1530lbs Loader-10470lbs
501-1965
891-1966
2501-1967
3544-1968
4065-1969
500c 1970-74 [ 407 ]
WT-9500lbs Loader-11900lbs
1377-1970
2577-1971
3189-1972
3018-1973
4961-1974
500e 1975-78
WT-10700lbs Loader-12359lbs
6000-1975
6445-1976
6822-1977
7187-1978
T340 TD340 TD340a 1959-65
WT-5532lbs & 5821lbs Loader-8694lbs & 8844lbs
501-1959
1979-1960
4344-1961
5449-1962
6397-1963
7338-1964
8525-1965
BTD-5 was British designed and built - BD-144 diesel engine
DTD-5 was German built and used a DD-148 diesel engine
I have obtained a list of Serial Numbers of most the IH Great Britain built Construction Equipment - Crawlers, Crawler Loaders, Pay Loaders & Industrial tractors.
If anyone has a particular British built model they need to find a Serial Number list for, send me a PM and I will do my best.
Regards from Michael Halsall B)
The first 530s were built in Japan serial 17501 without a J in the serial number. They were branded Kimco (Komatsu International Manufacturing Company).For mostly Asian / Pacific markets. They were also made in Canada for all markets (Candiac Plant).They were made in Libertyville plant and finally to HSW in Poland.
Tom
Are there any breakdowns to the suffixes to the serial numbers?  I have seen someone suggest that the numbers and letters after a serial number are about the equipment the crawler was provided with we have 1946 T-6 serial number TBK13571 T7CL.  What do the last 4 letters and numbers refer to?
We have two IH 3616 Backhoes.  The serial numbers are 1127 D and 2134 D.  Can anyone tell me what year they were manufactured?  I can't locate a block date, only the casting numbers.  I looked at the serial numbers listed, but none were for this series.  Any advice on where to research the serial numbers would be appreciated.  Thank you.
Since I last posted, I have located the engine serial numbers and the casting dates on the manifolds and the engines.  They are as follows:
IH 3616 Backhoe Serial # 1127 D    Eng #  D236 16683    Eng Casting Date:  8 - 22 O    Manifold Casting Date:  9 - 100   Which I think means 9 - 10 - O
IH 3616 Backhoe Serial # 2134 D   Eng #  D236 17644    Eng Casting Date:  2 - 9 - M    Manifold Casting Date:  3 - 4 - M
Can anyone verify to me that M is for the year 1966?  And that, O is for the year 1968?   If so, it wouldn't mean those are year of manufacture, but it would narrow down the possible years.  I found those letters used for the IH Cub.
Thanks for any information you might have for me.
Casting codes for US built tractor    L - 1965
                                                        M - 1966
                                                        N - 1967
                                                        O - 1968
                                                        P - 1969
                                                        R - 1970
                                                        S - 1971
                                                        The 3616 was built from 1965 - 71 according to TractorData.com
                                                        Regards from Michael HB)
Thank you, Michael. This is probably as close as I can get to the year of manufacture of these two backhoes as I haven't been able to locate any serial number years.
I've glazed over this article/thread and didn't see This detail
FYI:
The engine casting date is when the engine block was cast, after which the foundry would warehouse the raw castings three months or more allowing the castings to cure.
So the Engine Casting date gives general information about the engine and why the engine casting dates and the out/production dates aren't the same.
On 4/25/2011 at 10:00 AM, M Diesel said:
This thread contains IH construction equipment serial number lists and engine cross reference information. Excellent info for ascertaining the year of manufacture of your crawler tractor and the engine it uses, not to mention the other machines that use the same engine.
If you have questions about your machine, post them as new topics. If you have additional info pertaining to this topic, please feel free to add it.
Starting this off with this web site link to a set of very nice serial number lists.
http://www.dozerpart.../page/420251932
Many thanks to those who post here. :)
I'm looking at TD-14A serial number TDF34659.  There are differences between that one & my -14A serial number TDF36246 manufactured in the same year.  I'm told by my "main mechanic" that farm tractors were built with different gear ratios or rear end ratios, giving higher speeds/gear.  Is there any way to find out if this is correct, other than putting the two tractors side by side, picking a gear & see what happens?  He was guessing that the farm tractor might be geared too high for plowing snow, which is my main reason for having the tractor.
