2290 Case
12 replies to this topic
#11 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 7,080 posts
Posted 22 October 2010 - 08:10 PM
I used to work at a Case dealer, BEWARE of the transmission, when it is working it is a marginal at best trans. Wide powershift gear changes, poor clutch pedal modulation for close quarters work (backing up to equipment is awful) In operation you can tell that the trans PS unit is not long for the world. The torque limiter on the flywheel is a weak link and the cheapest to replace. When you need to do the PS clutch packs, it is a MAJOR job and is very expensive. The aftermarket has not started to make trans parts, as they are a relitivly low number of them built. USE CAUTION IMHO
"Rooster" 1066 puller tractor,
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered.Cub 1572 Diesel  CanAm 800
 Dodge Cummins truck 2013"Buckweet"yes its automatic transmission
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#12 IHCubguy
IHCubguy
  • Members
  • PipPipPip
  • 803 posts
Posted 22 October 2010 - 08:40 PM
I have to ask you guys here on this one. Did Case change the tranny on these from the prior Agri-King 70 series line? We had the forerunner model to this a 1270 and absolutely LOVED that tractor. We had very little trouble with the 1270. I will admit it had the tranny apart for the usual broken bolt issue on the clutch pack that they suffer from. But I believe it was more from operator error than from a bad design as it was early on and we owned it quite a few years after that and it was trouble free. We upgraded to a 7120 only because we were looking for a bit more modern tractor and after having both of them I would honestly take the 1270 back anyday of the week as far as brute power and traction. The Magnum struggles on some of our hills for traction where the Case would just power thru and walk away with the load, and the Case had bias ply tires where the Magnum has Radials.
Here's some pics of the old girl the day she left and some of the replacement for her. I'm not trying to stir the pot, just sharing my experience with a Case and maybe learning something as well along the way.
Farm tractors: 1924 15-30 McCormick Deering, 1926 15-30 McCormick Deering, 1936 Case RC, 1937 F-20N, 1943 H, 1944 H, 1944 JD A, 1946 H, 1947 M, 1947 CUB, 1951 H, 1952 M, 1952 Case DC, 1960 560D, 1962 340D, 1973 766D
Garden tractors: 3 Originals, 2 70's, 100, 122, 123, 124, 106, 107, 126, 73, 800, IH built 782 and 982, 782D, 1572, 318JD, MF12H.
#13 harvester66
harvester66
  • Members
  • PipPipPip
  • 226 posts
Posted 22 October 2010 - 09:14 PM
I have OH alot of these powershift trans they are all built on the same concept 4 clutch packs the more HP case just added more clutches and as you said went to 1/2 bolts. I will agree operator error has alot to do with problems. such as not down shifting maunally before clutching. cluthing from 3rd. can get very$$$$.
1949 W4, 656, 1466, 1586, 1660, 1946 W4, 1939 H (puller), 3688 serial 800, 1206 wheatland
