Hoot
"Switch" Plows
Sometime ago someone on here mentioned that rollover plows in their area were a thing of the past and said that they have gone to switch plows instead. At that time I never gave it a thought and asked what they meant until recently when I saw a picture of a switch plow on NAT. It was a John Deere, it appeared to be semi mounted and it had odd shaped looking moldboards with landsides on both sides and no colters.
I have a couple of questions; I'm assuming that they do the same thing rollover plows do but how do they change from one side to another? Did IH or CaseIH ever offer any of these plows?
I made the switch to a rollover plow this fall and so far I really like it, it has several advantages over a one way plow. Being a plow nut I was just curious about switch plows and was wondering if anyone that uses one or is around them could tell me about them, or even post pictures of one, thanks.
Around here we can't hardly use a one way plow so you mainly see rollover plows. But I am looking at getting a switch plow and seeing how I like the trash coverage. I see an advantage with the switch plow as being weight. Most all of them but the biggest are fully integral and the have a pivot point at about 1/3 of the way back from the hitch and they have a ram and shift linkage at the hitch the locks the bottoms and beam to one side or the other. When you plow one way the ram is fully retracted and locked at the certain right or left angle and when you turn around you extend the ram and that "switch's" the plow bottoms to the opposite angle.
I want to go to one and try it out because while we do great with rollovers sometimes if the plow doesn't roll perfect every time it puts a lot of stress on the hitch and rear of the tractor. A switch plow weighs less and there is no stressful roll motion is the way I look at it. And you only have one set of bottoms to maintain.
These plows, more or less push the soil over, don't turn the soil over as well as a regular mold board plow... Around here they were real popular for several years... Most of them were probably sold for scrap last summer... John Deere, Long Mfg. (tobacco equipment), Harrell Mfg. (cotton harvest equipment), Lewis M. Carter Mfg., were among the brands that were popular in this area.
More from .... http://www.youtube.com/watch?v=2L9xLatfit8
Long's patent.... http://www.freepatentsonline.com/5024281.html
New Ag thread... http://talk.newagtalk.com/forums/thread-view.asp?tid=76907
Hoot the best was to describe them is think of how a grader blade will roll dirt when it is angled. The switch plow is basically 3 to 5 mini grader blades. They are not as heavy on the rear of the tractor but are tough on the front end. You have to have a lot of weight on the front end to keep the plow from swinging the tractor around. Eason
A local tater farmer here has one, 5b i think, they seem to like it. fields look pretty good after their done, smooth enough to drill in some rye as a winter cover.
The plow bottoms look like what we use by hand around here to move snow with. (or so that's what I saw in the video).
