Andrew Fritsche
Harvesting Peas
The last ten years i have worked For Del Monte harvesting peas, Here we are in action, THe combine are FMC- OXBO ( Oxbo bought out FMC a few years ago) 6 wheel drive with Deere power. The cabs on the older one are Claas and the new yellow one are Deeres.
post-145-1216826961_thumb.jpgCombining peas
post-145-1216827011_thumb.jpgThe Computer that controls the functions and monitors everything
post-145-1216827053_thumb.jpgWe Somtimes watch TV :)
post-145-1216827071_thumb.jpgOur Cart
post-145-1216827088_thumb.jpgDumping on the truck, The Trucks are local Farmers who are Contracted to haul the peas, they get paid by the Hour for this and by the ton when they haul Sweet Corn.
I really like that straight truck! So do you run the harvester or a dump cart? How big of an area do they cover, just Minn or other states?
I worked in the early 80's for three summers on a pea harvesting crew. First summer on a pull type FMC 005 coupled to a 1066, two more summers with a FMC125 stripper, one of the first around anywhere. They were great times and the best job I ever had. We worked like dogs for six weeks or so, and I made about three times as much money as my buddies due to the 18 hour days. The 1066 on the pull type was a blast, tons of road travel, we often would travel 30-40 miles per day since the crop was all over, and matured at different rates. Loved a 1066 at 24 mph. Peas are really sensitive to heat in how fast they mature, so fields planted in a series don't always harvest in series, so there was a lot of travel. Here is a pretty good website if anyone is interested in how pea combines work. They are a pretty cool machine, way-way-way more expensive to buy than a grain combine, like about 3-4 times as much. Running these machines made me want to be an agricultural engineer. Someone forgot to tell me though the the farm equipment industry would die while I was at university! No matter, has still been a good ride.
http://www.toytractortimes.com/tttsubscrib...trkjune2004.htm
Andrew,
Neat!
Thanks for the view, we don't see equipment like that down here.
:D
Thanks Andrew. We have had peas grown in my area of central Michigan in the past and there may be some again this, I don't know. But I seem to always be gone to work or away from home when they get harvested. I believe the peas grown here are under contract for Gerbers out of Fremont.
For those that are wondering what FMC model PSC-156 means, its a Pod Stripping Combine with a 15 foot drum 6 feet around, PSC-156 :)
I too harvested peas with a pull type FMC back in the late '70's.
I worked for Twin City Foods out of Stanwood, WA.
The year I worked for them was the first year they had IHC 1066 Hydros to pull the combines. Great tractor but they don't run so very will without oil in the sump. As a consequence we were short one 1066 Hydro.
I got to operate the replacement because no one else could run the IH gasser tractor they hauled out of the barn to replace the 1066 with the blown engine.
The old girl could keep up except for the electrical system. You had to run throttled down so much that when you stopped to unload you had to firewall the throttle or by the morning the battery would be dead.
As IHSteve mentioned, we had to do a lot of road work because the farms were all over and were not always ready to be harvested in sequence. Our longest move was over forty miles. That can seem like a really LOOOOOOOOOOOONG way when you are going less than 20 MPH and the only thing you can see in the dark is the combine in front of you.
I was on the night shift and we did most of the movements. At 2:00 A.M. there is not nearly as many drivers as there is at 2:00 P.M. Even still, one drunk was able to pass eleven combines, a shop truck, and a tractor pulling a compressor to run into the back end of the front combine--all with work lights, headlights, taillights, and rotating beacons
His excuse was he didn't see it!
It was one of the best summers I ever worked--good pay, short season.
I remember the pea harvest my dad an uncle used to grow peas for columbia foods with used to be cedargreens out of snohomish we used to be the the first farm on the west side they would harvest before heading north towards snohomish and every were else alot of fun but trying to plant by calender in western washington is not very fun to bad most all of the canneries left because of the regulations and went east at least on the west side we dont have to buy water
I DROVE A CUTTER FOR HORTONVILLE CANNING COMPANY OUT OF HORTONVILLE / WISCONSIN. THERE WAS 3 CUTTERS AND ABOUT10-12 PULL BEHIND COMBINES THAT WERE PULLED WITH NEW MAGNUMS. THE FIRST YEAR OF CASE / IH. US CUTTERS WE COULD CUT AHEAD FOR A FEW HOURS THEN SLEEP UNDER THE TRACTOR FOR HOURS. THE COMBINES WERE PULLED BEHIND IN LOW GEAR. THE CUTTER TRACTORS WERE WHITE 2-70'S MAN THEY COULD MOVE ON THE ROAD. MADE GOOD MONEY FOR 2-3 WEEKS. FUN MET SOME GOOD PEOPLE MET A GAL AT THE END OF HARVEST HAD SOME FUN THERE TOO HEHEHE
In the middle to later 60s I drove a truck for a friend contracted to Del Monte in Rochelle IL. Hauled peas and sweetcorn. The truck was paid by the hour.
The pea harvesters were FMC and Hammachek (spelling?) These were pulled mostly by Minneapolis Molines. 602s with a double torque to get them to go slow enough. One crew had 806 diesels.
The Fmc machines had MM engines and the Hammachek had a 60hp overhead valve Wisconsin.
These all ran on LP (except the 806s). In those days Del Monte was its own MM dealer and ran all MM tractors. The 806s were leased. The LP tank was pulled by a G MM that ran on gas and had a pipe frame on the front so he could push trucks that were stuck. A board on the back of your truck was a must to protect it when pushed by this tractor.
The peas were mowed with farmall Ms with a mower on the back, and they drove them backward mowing. They had a couple of case self propelled windrowers also.
We would not stop for rain, and that was why the push tractor was necessary. If the one pushing was not enough, they would get one in the front to pull also. Lots of 16-18 hour days. Good times
Seems like everyone has fun doing peas, fun crop to harvest, can be done in all kinds of weather (fun in a cab at least) and what I like was that there was no dust. The guys I worked for were all IH, which made it even better. Hydro 70's and 86's on the cutters, anything from 656, 1256, 986 and 1066's on the pull type combines. On the flat and dry they pulled pretty easy, but on hills and stopping at full speed road travel the larger tractors were necessary. Pull types had bullet proof Chrysler slant sixes that just ran and ran. The first FMC stripper that I ran had a Deutz engine, 160 HP that was totally balls to the wall, never felt heat from an engine like that thing. Had a ton of trouble with it the first year due to some timing issues from new. We also ran a Chisholm Ryder stripper with a 4-71T Detroit, now that was noisey, but luckily the engine was no where near the cab, but on a clear night I could hear it from 3-4 miles away coming to the field, once the bugs were worked out it was a good combine. We ran 6 combines, had an emptied out school bus as a mobile workshop with a welder, generator and pressure washer and parts, along with an army of trucks, mostly Loadstars. Crazy as it was we even took them across water on a large ferry to harvest on a large island community, that was a bit scarey when you drove on and the ferry would go down a lot. Competitors ran Hamcheks with JD engines, good machines as well. Back in the day stationary combines were used, called pea viners then, since they harvested the vines and pods together and with a "pea loader" would load trucks to take the vines to the stationary machines. That would then create a "pea stack" of a mountain of pea vines from the stationary machines output, that would be tramped in a stack (kept an army of teenagers busy on the forks) and then would be sold over the winter to dairy farmers as silage, a real great source of feed high in protein, smelled a bit rank. I can remember going with my dad in the late 60's to get loads several times each week in the winter.
The really old days: http://gesswhoto.com/um-pea-production.html
I had heard that the dairy farmers that used pea stacks for feed, had a taste problem with the milk.
I ran a pea combine 6 weeks summer of 86 and 87 . We were cutting for McCain foods. Hesston swather and a group of 4 combines. Field boss and company mechanic. One tractor was a company Ford TW 25. The rest of us drove tractors rented from the farmers growing the peas . 15 $ per hour for tractor with driver. McCain supplied the fuel. Also hired pea grower trucks. We cut an average of 22 acres per day so they supervised sowing in the spring . For the most part they matured in order by field boss strickly controlling spring planting.
!st year I had 2-105 White with cab , back window out. Second year 966 no cab.Cut alot of peas in rainsuit as they would harden faster in warm rain then sun. We had some FMC and I pulled Mammecheck (SP?) . Those slant sixs were reliable til started missing when a cloud went overhead. Mech repaced more dist,points , wires,coils , etc than anything else. 966 was twice the tractor the White could ever be.
Our combines had the Chrysler Industrial slant six for power. The only problem we ever had with them was sometimes when they were hot they were a little hard to start.
We had a crew of swathers that would go through ahead of the combines-two Owattana's (sp?) and one really old New Holland.
I got to run a swather a little. The Owattana's had two really short joy sticks for controls--a little touchy but once you got the feel of it they were pretty nice. The clutches in the NH were about gone. You had to hold each control at a different pressure or you would go in circles. The NH was a lot better in wet fields than the O's were. I think it was mostly the NH had a lot larger tires and would float more.
The NH had a 30-gallon drum filled with concrete above the tail wheel. Even still, it tended to be rather light on the rear end. You could stand it up really easily if you weren't careful.
Nice pictures. Thanks for sharing them. Seems like it would have to be pretty gentle in the seperator area to thrash peas without alot of damage to them. I always like to see stuff like this. Thanks again.
