gonzo 1066
Transmission pictures.
Just got a transmission for the puller toy..
That is new cast? What is it just 2 speeds
The cast housing is the stock 706-1486 transmission housing.   It is milled out to take a twin countershaft 5 speed transmission.     The 5 speed is a stand alone aluminum case transmission built for pull tractors.
That is what happened to all our old ihc tractors up here. 15 years ago they were getting bought going east  up for puller parts.  I see now the top piece  added. Nice to see your puller projects again gonzo.
Did you pick it up gonzo?    If you did you were only about an hour away from me.
Nate
Dumb question but what do you use for a starter?
If you are using a front mount starter make sure you check inside the housing where the starter goes for clearance. Starter gear probably will hit the housing and not go very far into the flywheel gear unless you grind it out.
The rear engine plate is milled to fit a powerstroke starter.   Steel flywheel is machined for a front ring gear..
Nate
I had Karl truck freight the trans to me.
Spent last weekend at Gordyville still amazed at how this sport has progressed and the amazing fabrication that goes into today's pullers.
4 hours ago, Thesd5488 said:
Do you still run the range tranny behind or is it direct to pinion
Direct to the pinion The new transmission has its own reverse gear.
Looks nice. Can you switch gears our for different gear ratios fairly easy? Is 5th gear in that one direct or overdrive?
 4th and 5th are overdrive.   5th is about 20% over.  The trans has to be removed and taken apart to change ratios.   But that is not too hard.
On 12/11/2017 at 5:50 PM, Driver1 said:
Gonzo nice to see you on the forum, was wondering where you were?
I had some large life changes..    Mostly doing the hermit thing for the last 2 years.    Just now I have started to engage with people again.
     Good to hear
          We have missed you here.
         Looking forward to see this latest project on track.
     Tony
 What model will it resemble when finished?
The plan is to use my 5088 hood on it..      I have a fiberglass 1066 hood, but everyone has a 1066 puller.
That will be a good look.
Wrap an H hood around it and call it "What the H"????  Just kidding, looking forward to pictures of it as you go.
Lol
Welcome back Gonzo
I think that's a perfect use for that Ol gal.  Feel bad for her sitting there.😊
This project can cleanse the shop and tools a bit after the long running green project.  Also i think red will highlight the quality of the work you do better than the other color.
Hey gonzo, if it's not to much trouble can you start a build thread so we can watch the deal?   I would really enjoy seeing it, and maybe others would to?
thank you
Good to hear from you again gonzo!
