JimG
international 350 u hyd pump
Does anyone know of where to get a hyd pump for a 350 utility  diesel repaired or where to get parts.
Am not having any luck with getting it repaired or finding any parts.
what's wrong with your pump?
Doesn't look original but a gas one will work if nothing else is found or until something shows up.. Like used on some SH and the 300 and 350. Need to put your drive gear on.
have you done this ....? as the ports,rotation and mount would be different?
continental diesel to gas one not the same an 2 different ones were used on diesel model good day
I have used a 350 gas one put a big frost plug in the distributer drive and cut off the distributer mounting pads looks different works fine
No but saw it done. Pump just mounts with inlet and outlet pointing up instead of down. Have seen the ignition flange just left open, a plate bolted over opening or a plug installed.
