lach13
86 series Hydraulic TA problems
Hi all, after searching the web and the forum I finally decided to create a new topic. To get down to basics I have found my self looking at an 886 which was a former family tractor. The tractor has recently come up for sale with only 4600 hrs on it, so i went and had a look at it today. My main issue is with the TA;  when changing between either speed you cannot feel any speed change. The lever has plenty of resistance and sort of snapping feel to it so I was thinking that it probably wouldn't be a cable issue, but i could be wrong too. Just looking for any ideas as to what could be wrong with it before purchasing as I have never had anything to do with one.
Thanks in advance Lachlan
The one 786 I've got did exactly what you describe. Found out that the one snap ring on the quill shaft somehow popped off the groove and let the shaft move enough that the hydraulic pressure blew out the teflon seal on the ta. Weird things happen. Not saying that is what the problem is with that 886.
If you are considering this tractor buy it with the mind set that it will need a TA.
the linkage may be broken on the firewall which would allow for the detent spring to make it feel like it is still shifting. a quick look under the left cab steps to see if the ta spool is moving up and down when you move the handle would tell you if the linkage is operating properly. the snapring on the ta spool should just make contact with the retaining nut when shifting to direct drive
It could very well be cable and linkage related. Common for the piece that hooks to lever linkage on firewall under the hood to break because it rusted up. Check everything for movement. With lever ahead, the snapring on the valve that the cable shifts should be just about  touching the retaining nut on the valve body.
Ha funny,  jus what he said. Lol.   We were typing at same time😁
The mechanical linkage for the T/A is troublesome to start with and if the tractor sits a lot is even more of a problem.
Its likely the T/A is bad, but start with making sure the linkage does all work and is adjusted properly by the book.
I've put on a couple electric T/A kits on tractors I own myself the last couple years and so far have been happy with them as they have eliminated the frequent linkage hassles.
We will see how they do long term after they get some age on them.
check the cable if the lower linkage binds up it will kink the cable handle still has resistance but the spool's not moving
Thanks everyone for their replies, so in the worst case scenario the TA is out will it hurt anything if the machine is driven like that until it gets fixed? And how much work is it to replace one?
Thanks Lachlan
Most farmers drive them until they won't go anymore before fixing the TA.
It is a significant job to replace the TA. The tractor must be split twice to remove the TA section of the transmission. Here in the USA it's a pretty common job and there are independent shops that specialize in jobs like this. We can take the TA section to a shop and they will replace the TA in a day for  around $2000 US. Not sure about Australia.
That sounds like a pretty fair price for the amount of labour involved... doubt I could find anyone that could come close to that price in Canada..
I have had my 1086 for many years now, and the TA has never worked... I assumed it was internal, and as the tractor has always worked fine without the TA, have never bothered to have it repaired.. use it mostly for haying and feeding, with some plowing, disc work, and cultivating...
I am going to order a service/repair manual, and will check out the linkages and cables to make sure that is not my issue.. will be good to have the manuals on hand regardless..
north, that $2000 only covers the work on the TA section itself. You have to disassemble the tractor and get the TA section to their shop, then put the tractor back together.
The TA itself isn't all that expensive. It's all the work getting to it, and all the other things you "may as well" do while you're in there that adds up.
Just an update, I have bought the tractor with the idea of the TA being shot which most likely will get fixed one day. Im a mechanic at the local agco dealer so hopefully should be able to do it all myself. Other than the TA the tractor seems in really good mechanical condition, it just has a few patches of rust in the cab that will need to be cut out and replaced. I would just like to thank everyone for their input.
Lachlan
That makes more sense...
Lachlan
Congrats!  Post a picture when you get a chance! :)
