mader656
Grain bins are never permanent
Future woodshed it's got a wooden floor...needs to be in the yard close to buildings....
Re-purposing is good mader.
Finding all kinds of things to do with that re-fabbed blade!
That pintle hose holder came in handy....
Id have gotten more pictures but one I got moving I did not want to stop...I expected to fight it all the way but it came good so I did not stop....
Now the fun part filling it...
I need a old elevator hmm....
Looks good Mader!
One of my friends sons re purposed one as a bird house for guineas. Before that it was a wood shed, and before that it was actually used as a grain bin. So it goes to show, things can be reused multiple times. Good job Mader!!!!!
Alan
Good use for a grain bin. I've seen others do the same for wood storage. Works well.
Filling it grain bin hold a lot of wood...
 Mader----
What all did you do on your door modification (if any)??
I keep thinking about converting one or two of my 24 ft bins into dry storage.  It's got a concrete floor base with the false aeration floor.   Been thinking about ideas on an 8+/- ft wide door.  Got some ideas-----but open to suggestions.
Total capacity and auger configuration is just about too small/slow to keep up with modern combine capacity these days.  Old storage building is falling in-----might as well use what I have.
DD
45 minutes ago, Delta Dirt said:
 Mader----
DD
Just the normal door but the braces are cut out....so I don't if no grain it shouldn't need much support with no wall pressure....I I was to put in a larger door I'd frame it with square tube or angle steel.
Lots of grain bin storage round here....
Think I will get the aeration floor pulled-----and go forward from there.
The bottom ring is set in concrete which will have to be cut-----but do think I will need a sturdy framework for the door so to keep structure strength in place.
I just saw a bin damaged from a windstorm on a farm I was inspecting recently------probably lucky it was empty when storm hit.  Did not take roof off-----but put a big crunch in roof and the back side of bin.  The strength of the bin is dependent on the circle being complete.
Your wood shed looks good-----and you've got firewood on hand in case Mama throws you out of house!!!;)
DD
