Brian W
706 narrow front
Hello again, just have a question on narrow front ends. Just picked up a 706 gas at auction. I don't need it at all but I think I want to keep it and would like to put a narrow front end on it. Which ones will work 560 series, or 656, or is the large frame tractors different. Thanks
I believe they all have the same bolt pattern.  I had the small pedestal on a 1256 for probably 6-8 years for tractor pulling, and light duty farming, never broke it.  So you should be ok with the lighter pedestal if you are not bouncing through plow furrows, or have 600 lbs on the front end.
stay away from the 656 which is the same as the 460 if you can. they  have much lighter spindles, hubs  and bearings than a 560 or 706.
ed
