hardknocks
pto housing seal area
have a pto out of a 1066 and the seal area is grooved.  does anybody have the dimemsions of the hole. going to have it cut out and sleeve installed to OEM specs.
If you are talking about the 540 shaft seal it is actually threads and the seal has to be installed from the inside. If you are talking about the main housing where clutch cup seals ride make sure you check all your bearings good, and the little needle bearing inside of the pump / clutch drive gear. Ag Parts & Hy-Cap have replacement exchange housings. Ag Parts also has the sleeve for doing it yourself. You should be able the measure between the grooves to get the proper dimension.
Yes I should have made myself clear it is the clutch cup. Seal area. I don't need to buy it I can replace it myself just need new measurement so I can make the replacement bushing
