jdjd
Hydro 84 high pressure relief valve location?
Where is the high pressure relief valve located on a Hydro 84? Is it the one thats in the MCV valve? If not where is it and how do I get to it?
Also  should the trans oil level come up all the way in the dip stick tube when checking the oil level? It does this if I run the engine at 1600 rpm,s as the manual states to check it.
High pressure relief valves for the hydrostatic drive is located in the center section. I believe you can get at them from the side cover . May only get at one on each side of tractor as there is one for forward and one for reverse.
