Vanstractors
Tractor Pull Roller
Picked up a wobble wheel roller to  use on our local brush pull .Any pullers see a problem using multi rib  9.5 L tires instead of those very expensive compactor tires ? Got to have 13  .Thanks
Implement tires are usually round-faced, not ideal for packing.
used truck tires work better than implement tires.
jerry
Yes we just went through this same deal , we bought new 14 ply bias ply steer tires for a truck . After working an entire evening mounting them they worked one pull and then they tore the steams off the inter tubes . Well we were dumb enough to put new tubes in again , well they went flat again . After talking to a couple tire shops they told us you can only run those smooth packer tires .
We went to Amish front wheels , my friend owns a welding shop and he cut out steel plates and we made steel wheels for the front 😊
Danny
Plane tires would be the ticket 😊
8.25TR15 lowbed tires?   They have stout sidewalls.  Unfortunately they are not as common as they used to be 20-30 years ago, so finding used tires might be difficult.  But if you sprang for new tires they would probably outlive you.   Forklifts also use 8.25-15 tires in some instances with even HEAVIER sidewalls.
Worn out set of skid teer tires?
6 minutes ago, G Huffman said:
Get some heavy duty tires and get them filled with foam.
Might be the winner more weight too.
thats an idea, i see used foam filled skid steer tires on the rim for sale on craigslist often enough
