hank1010
TD 6 compression release lever
Hank, All good suggestions here to check and confirm. I kept looking at the linkage behind the manifold and I couldnt see the plate on the vertical rod that goes up to the head to open the start valves. THis plate sets between the "V" flipper that opens and closes the main manifold butterfly valves. If this plate is missing, there is no mechanism to close the main butterfly valve on gas cycle and open them when you convert over to diesel cycle. It may be there and I just dont see it from the angle of the photo. Keep up the good work, Jim.
Hank,
 Whats happening on the 6? I know its cold out there now. You may just be resting waiting for some warm weather?
Regards,
Chris
