I believe I understand correctly that there should be a timing pin near the crankshaft pulley, but I do not have one. Can anyone tell me if I'm just not seeing it or if mine has broken off? If it is gone, where do I put the replacement? Thanks in advance for the advice and encouragement you've given so far on this board.
Farmall A and B used timing marks on the flywheel not the front pulley. Take the plug out of the bottom of the bellhousing and turn engine over until you see the marks.
Marty,NZ
I didn't even have to look at the flywheel.  I got it on TDC, set the points, and it fired up.
Thanks for the words of wisdom to you all.
