Lt.513-2
New addition Farmall M
Today the F20 was put to work pulling the new project home. The M only lived about 1/2 mile away, through hills valleys. Not sure how long the tractor sat idle. Engine is loose and radiator has decent looking fluid in it, clutch may need some attention or adjustment ? I was a little worried how the F20 would do. It did an excellent job pulling through the decent hills between my house and the farm it lived on. It is a 1947.  I'm not sure if I would need to make YouTube video ( which I haven't signed up yet) so I can post a video here , or can I just copy and paste?
It looks like a nice one to start with
Nice M.  They are still hiding out there tucked away.
I worked on a barn East of you in Chester County years ago. There was an H in that barn that was no doubt an original low hour tractor  sitting on the tires it came with. I wanted it really badly but the owners wouldn't make a decision one way or the other.
Nice looking M
i have a 48 M. Best tractor I've ever had.
Thanks everyone! Today was just trying to get it to run. The starter needs help, it's still the 6 volt positive ground. Most likely will need a carb clean. The engine barely turns over...had a few puffs with it turning over but no good "pops". So things were getting the best of me, I coasted back and then down the drive to the road. The  M fired a little and then died. The trusty F20 had to come and rescue it back to the house. It was getting late in the day so i don't have pictures of my youngest son steering the tractor. His face was priceless as we went around the barn on a slope.. he thought it was going to tip over. It was the first time he steered with a push pole on the front of a tractor, so a lot of coaching was in order. He did do a good job once he got the hang of it.
            Tom H the story with the M is similar to yours. I've always wanted a M. I was on the farm a few years ago hunting groundhogs and i seen it sitting there. A few years pass, he came to the shop, that's when i asked him what his plans were. He wasn't ready at the time to let it go. He comes a year later and asked what i would give for it. I said without looking it over good i would't give over $800. He and i set up a time and got to looking it over, I offered $500 and the tractor was mine. There is a few " farmer fixes " to address nothing that a little time and money won't solve.
            Jason
Update the M is running good. Just a carb clean and a pop start to get it fired up ! It runs good,  but i think it may need a few RPM's. There is some valve tap, still runs smooth though. Doesn't smoke hardly at all. The tires seem to have some " bounce " in them when in 5th gear. Could this be from sitting flat for quite awhile ? Or maybe the brand of tires ?
             Jason
Looks like a good start and a good price.  Tires that have sat like that for years without being used can develop a "flat spot" for sure.  That could be the tires and it could be the speed of 5th gear.  Not that there is anything wrong with your tractor just more speed will find more bounce anyhow regardless of tire or tractor.  The tires look to have very good tread left.
Looks great!  I love an M.  Have fun!
An update on the M, Adjusted the valves to try and get the valve tap out. The manual says .017 hot. I did run it for about  15 minutes or so . Started it up and ran good until i took it down to idle. It was revving up and down like a carburetor issue , i think i may have set the valves a little too tight ? Any thoughts ? I'm going to try again and see if i run it longer and adjust the valves at that time.
                      Jason
                      Jason
The surging you are describing could be the governor acting up. Probably needs lubricated to free the weights up. Good luck! Nice M.
Dad uses his 460 gas on a PTO GEN when he needs to, it's governor is really slow to react to the load.  you can watch the lights go up and down
"Hot " might be a relative term. Depending on the manual. IT manual defines hot as warmer than 70deg or something.like that. In other words dont set em at 20 below with engine cold in those cond. Ok to set at room temp 70 or warmer iirc.
Pretty nice rear tires on it, first thing I look at , your well on your way ,Avanti !
            Jason
Wow , that was a good offer , good luck , those rear tires are worth more than that but I can't look at them real close but anyway good for you .
i usally squirt sure 2 stroke into the cylinders and turn it over a few times and let set over night and repeat it . 2 or three times .
its turning over slow ,the cables are shot with corrosion, replace with 0 or one gage that starter will come alive if you clean commutator like in book recommends
any way nice m
any way nice m
Dennis it does turn slow right now. I did get the starter rebuilt and replaced the cables with 0 gauge, but my problem still must be the battery (weak ). It also could use new wires new solenoid etc....  It was converted to a push button instead of the foot start. I'ts been sitting since 90 something...
                             Jason
11 hours ago, kracked1 said:
6v will not spin over like 12v.
Yes understood, i don't have plans to do the 12 volt conversion yet.The battery that was with the tractor was an 8 volt. I will need to do some checking to see if they adjusted the regulator and generator to be able to charge the 8 volt battery. Gotta love farmer fixes on these old tractors ! Tractor wrenching will continue here when spring arrives in 2018
We have a super M that we bought new and we switched to an 8 volt battery.
It works good. Not as good as 12v but better than 6v.
Uses all stock parts, just need to adjust regulator. Discharges a little at idle but has worked for 65 years.
That being said 8v batteries are getting hard to find and ain't cheap. If it needs a battery now might be good time to go to 12v.
If you want factory look get a 12v generator and regulator off 560 or 656 and your good or if factory look isn't an issue for you than go with alternator.
Uncle George had an M he bought brand-new he said they converted that to 12 volt the H he bought they converted 8 volt the H with a smaller engine would start okay on 8 volt the M needed 12-volt now we're in a colder climate here some of you guys could get away with 6 volt probably fairly easily
Congratulations !
  Looks like a nice project.
   Keep us posted on progress.
   Tony
