Today's progress is going a little better. What a cave inside, lots of cleaning to do.
Latest progress...determination required. For those that don't know you can't service the pinion bearings without pulling the steering clutch. I just happen to be headed there anyway.20171105_111336.thumb.jpg.c688bb869fad77415db2f2e3a3bee99d.jpg
Removed the left steering clutch yesterday everything went good however I still can not get the final housing off of the Main case.it will sperate about 1 inch then binds up somewhere on the pinion bearings. Hoping someone might have experience in this area. I have the manual and exploded views for reference but something seems siezed. The final case does move freely on the dead axle. Any help appericiated..
Perhaps these depictions will help
5a071cef3bc63_td69ihfinalsprocketdrive002.thumb.jpg.4cf0577d91de79343fbff72a2c48042c.jpg
5a071ce217267_td69ihfinalsprocketdrive001.thumb.jpg.3ec4a81630314d02b74ea1e8c9a98d8a.jpg
Thank you for the quick response and I do not have those views so helpful :) Back at it now, not to be defeated!
My back is sore :wacko:...got the pinion out but still hung on the inner pinion bearing o.d. as I read and re-read and re-read the manual it talks about using "puller cap screws" if it doesn't come apart. I'm looking through the holes in the drive plate for the right holes to use. Bent over the fender reefing on the pry bar for two days with little progress but getting closer. The technical writing from IH can be confusing. At least for me.  2 Aleave, easy chair and some football should help.
Pusher cap screws did the trick. Just had to figure out where to put them. Easy once you do it . Hope this helps someone else.
