timh
wd 9 injector pump
Looking for the seal that goes on the drive end of pump on wd9 . Any suggestions or part number would be great
BK Diesel in Dubuque IA , 563-583-9600 , talk to Mike , they the seal kits , do the transfer pump too and you need to be careful removing the gears and shafts or you will damage the bushings in the housing .
Danny
Is this the seal you are looking for? I replaced all the seals in mine this spring. I either located the PN from the original seal (I believe it was a Chicago Rawhide seal) or I measured the I.D. & O.D. & thickness and ordered one at carquest.
If you are looking for the seal at the primary pump end, then the info DirtBoyz provided will help you out. I believe they sell the primary pump seal kit ($125) which would have the seal you need.
Yes that is the seal I need! Do you happen to know the part # of the seal you used?
