Can I trouble one of you for the TD9 (92), DT 282,  6cyl, Torque & Timing Specifications?
Putting Rex back together and I only have the TD9 4cyl info in my manual.
If you have the specifications chapter or the service manual for the direct drive turbo 282, I would greatly appreciate it if you can post/email it?
Thanks in advance.
Nick
LF thank you!
I was reading some other posts on Inj. timing and mishaps with being 180* out. Anyone have suggestions on avoiding this or tips to making sure it correct at 3* ATC?
Nick
Gents.
Finally wrapping up the rebuild on Rex's 282 (2 piece crank) and my manual only shows the spec's for the 4 cylinder. Can I please trouble one you for the intake & exhaust valve lash spec's for the DT282 6 cyl.?
Also, any suggestions on the break in SAE oil grade/deration with the rebuild ( sleeves, pistons, bearings, crank, oil pump, etc)?
thanks,
Nick
.027 hot, .030 cold on both exhaust and intake. Break in oil? I  use 15-40 Delo 400 or a straight 30 weight diesel engine oil.
