Az.Nick    0
Hello Gents,
Been helping mom clean out the shop and have the following items she could use some experienced help on value?  Best of our knowledge everything is in working order if that helps.
TD15 or UD16 (I believe) rear cylinder head # 252572 R7 (still on crate pic below)
TD9 10 bolt Hydraulic pump (pic below)
IH hydraulic controls for TD9 91 or 92 with the Drott loader system. Husco Model U3600FM1 Sir. 95053
TD9 or T9 Upper Shaft 52220D SN 501 to 38334 (all below items in pic)
TD6 or T6 Lower Pinon Shaft's & carrier x2 58356 SN 3387 up (both bearings spin free)
TD6 or T6 31/37 tooth 56186DA   SN 592 up
TD6 or T6 41 tooth 51968DA  TD6 or T6 41 tooth SN 501 up
TD6 or T6 36 tooth Reverse gear for pinion shaft 260148R1 .
Thank you in advance,
crawlernut    0
Local Craigslist had a TD14A injector pump for 150.00. Shelf item, not sure of condition. I may be interested in the 18A  head if the condition is good and the price is tasty. No clue on gears and shafts. Jim.
Az.Nick    0
Jim,
Thanks for your reply!
Anyone else have input on values on below items?
TD15 or UD16 rear cylinder head # 252572 R7 (still on crate pic below)
TD6 or T6 Lower Pinon Shaft's & carrier x2 58356 SN 3387 up (both bearings good/spin free)
Thanks
Nick
Az.Nick    0
Fellas moving soon and below items need new home no charge, you ship! Dont want them to go to scrap!
TD15 or UD16 rear cylinder head # 252572 R7 (still on crate see pic)
TD6 or T6 Lower Pinon Shaft's & carrier (non beveled teeth) x2 58356 SN 3387 up (both bearings good/spin free/garage kept)
TD9 or T9 Upper Shaft 52220D SN 501 to 38334 ( in pic)
TD9 10 bolt Hydraulic pump (see pic)
PM me if you can use!
Thanks
Nick
adefreit    0
Hi Nick,
If you still have this, I would be interested in the unit. Can you tell me what you want for it and its approximate weight for shipping?
Your PM did not work. Thank you.
Alan
apdefreit@hotmail.com
