McCormick 40
1250 electric clutch problem
   Was mowing today and suddenly the blades stopped.  Checked it out and the clutch does not have power to it if the engine is running. You can turn the key on and the mower deck switch on with the engine off and you have about 12.4 volts going to the clutch but if you have the engine running you have 0 volts going to the clutch unless you kill the engine then you have 12.4 volts there again as soon as the engine stops turning.  Is there some kind of relay or something that is not working when the engine is running or what?  Thanks
