ih4life
Farmall 460 Hydraulics
5 posts in this topic
Currently removing the entire fast hitch system. I need to replace the valve block on the tower with another block now. What I'm wondering is if I should replace it with another one the same as the two on there or is there such a thing as a bypass block for non fast hitch tractors? I believe it should take another dual action block but then what good is it for? I've had many 460s and 560s over the years but now that I think of it never without a fast hitch.
What good would it be?  Had a 400 with three valves.  Loader with 2 way bucket front set.  One for cylinder on implement or fert auger.
why not remove FH and store in shed
plug or plumb lines into self   leave all as is   then you or new owner can go back if need /desired....?
Ive only had one 560 so far.....far as im concerned the fast hitch is one of the nice parts of the tractor....wouldnt really want a 4 or 560 without myself....might as well buy an M or 400-450...JMO
There is no block to eliminate a valve.  The tractors with only two valves had slightly different lever hookup.  What I would do is find another valve to replace the teledepth valve.  You cannot just leave that teledepth valve ( well, I should qualify that statement, you can leave it but you have to block it with a lockout cover  so it stays in neutral positon) .  Your linkage to the now new valve will need to be worked on to make a good operating system. You need to get rid of the quadrant and friction device.
You can leave the pipes to rear so you will now have a rear hook up.  Also, you can leave the check valve if desired so it will positively hold loads from drifting down, or up.  I say up because we used them that way to hold knife in the ground when applying nitrogen.
