Followers 0
motorisedwombat
8910 Transmission Lube press fault
2 posts in this topic
Hi all
8910 with trans lube press light coming on can someone help identify pressure sender on transmission. Can someone also explain why the light only comes on above a certain RPM, does the pressure sender only work in a certain pressure range or does the tractor only send power to the sender at a certain RPM.
Thanks
never mind found oil in connection plug on one of the sensors and going to take a stab and say its the faulty one.
for future readers it was the one under left foot if sitting in cab, comes off the same wiring loom as the diesel tank level sender. activates trans lube press light on dash.
Followers 0
