Followers 0
Good Hope IH
Worth of a running WD9/650/TD9 gas start diesel engine
2 posts in this topic
Was wondering what you guys think a running engine out of a 1952 TD9 would be worth? I have one that someone is trying to buy from me so was not sure what I should tell him I want for it. Was thinking somewhere around $750.
Hi Just depends on how good it is running.  I have what thought was a good running 600 diesel that had a very slight external head gasket leak.  Did not pressure the rad.  I thought a head gasket would fix.  It turned out the head was cracked, and a liner was cracker.  I pulled the engine all apart and also had a cracked block.  A head that is a good not cracked core is probably worth a $1000 Canadian funds  Good used parts for these engines will bring a good dollar, broken parts are not worth much  Good luck
Followers 0
