Followers 0
rmo826@aol.com
5088 hydraulics
24 posts in this topic
I was discing today and all of the sudden I could not lower the disc. The lever works fine.It will try to go down a little bit and just stops. I switched the hoses from top to bottom and it made no difference. If I put the hoses on the other set of hydraulics it works fine so it is not the couplers.I don't think it is the tractor couplers either. Is there any adjustment in the hydraulic valves on the right side of the tractor by the tire?
Your detent valve may have either loosened or tightened itself up. If you crawl under the tractor on the right side, pry the little cap off on the remote valve. Its facing straight down to the ground. The spool is inside the tube, should be able to see the end of them. These can be adjusted with a flat screwdriver. The handle needs to raise, lower and also go into float with the adjustments. Also do a check on all your linkage, just make sure nothing is worn to excessive and binding up.
Some of the 50 series were ordered with double acting check valves. If it has them they are a square block in the hydraulic lines above the axle, could be on one or more valves. If it has them could be broken springs in them or they could be worn out, I had to replace one that was shot.
It sonds to me like its the check valve because you can raise it but not lower the disc. Will check it out in the morning. Thanks alot
Not to hijack the thread, friend has a problem with 5288. Neither of his remotes will float. He said you can be in the down detent and go to float and he says it goes to the float detent but the implement wont float. Will a closed center system float with the engine off. Such as having a disc hooked up, with it in raised postion. Shut engine off, should it float being a closed system. We have had plenty of boxcar magnums but i guess i have never tried it.
Its probably one of the drop checks as others have said. If these are hanging they will not float either. The motor valve as far as I know never had the checks in them, so if you can plug in that one and everything is fine its the checks.
I worked on my 5088 today. Mine does have the block with the check valves on it. I unscrewed the plug on top and removed the spring and ball. Put the plug back in and the disc lowers as it should. Now it will even lower with the tractor off. Thanks for the help
Good deal
I am having the same problem with my 5488.  Can you tell me where and what the check valve looks like.  Some commented about it being above the axle,. I don't see any box type check valve.  Pics do wonders for me if you can get one.  I really need yalls help.
dont have any pics of it, but follow the lines from the rear couplers all the way to the remote valves..  If yours has it there will be a block in the lines along the way
Ok. After I posted earlier I got my dad to operate lever while I checked the linkage to make sure spool was moving far enough.  I also tapped on the spool.  It let the disk down.  Now it does the same thing opposite of staying raised.   It will not go up now.   If I don't have the check valve what is the next step?  Adjusting the spool with a screw driver from the bottom?
The outline is the check valve one will be on the left side and one on the right side if you have three remotes. Hydraulic lines come from valve stack behind the right hand battery and tire and run to the check valve block then come out the back and go to the rear of tractor to the remote coupler housings.
the screw you are talking about has nothing to do with flow.  It is for detent retention only.  Have you tried one of the other couplers. does it do the same thing?
That's the next thing I was gonna try mike.  It seems like the lines have pressure on them therefore making hard to unhook.  Now that it is down I hope I can get them unhooked and try the other outlet today.
If the lines seem to pressurize most likely one of the male pioneer tips or one of the female couplers is not opening. We have had many brand new male tips fail to work within a year of initial use.
I finally hit some time to work on the 5488.   The pressure released in the hydraulic lines.  Finally got the lines unhooked.   Tried in the other set of outlets and had the same problem.   I pulled the dipstick to check fluid level again. It sounds like it is sucking air when dipstick is pulled out.  I have not changed filters yet.  Any suggestions? When engaging the hydraulic levers it does put a strain on engine as it should.
Ours sounded like that since new. Not sure why but never caused any trouble.
I would try to change the ends on the hoses.
+1. If changing to the other remote didn't fix the problem, the problem is the tip end, not the tractor.
Well I changed the tips to some older more used tips and everything work fine as for the auxiliary valves go.  🙌   Three point arms are still not raising up all the way.   What's the advice on that?
But they are going up and down?.  There is a slotted hole on the control rod you can adjust to get more height.
Yes they are going up and down.  I pull lever all the way back as far as it will go.  It will actually hit the plastic back that the lever comes up thru. Arms only raise about half way up and stops.
look under the cab at the front of control arm there is a slotted hole.  Move it to the to other end of slot little at a time to get to go higher
Followers 0
