560Dennis
    2,662
1 Follower
About 560Dennis
  • Birthday 04/17/1949
  • ICQ
    Chardon,Oh.
    All Machinery in General , Passion for Farmall's, 560 Diesel , Farmall C , Restoring Fordson Model F ?? Year . Fairbanks Morse hit miss 1919 . Would like a Farmall M and H someday .
    Hunting and Fishing
3,549 profile views
  1. Happy Thanksgiving Every One
    Happy Thanksging to everybody ,thanks for all my blessings , could I have any better . Dought it ! Headed to Bob Evans ,now . We had our dinner on Sunday cause it was schedule conflicts , so we are alone, just go out to Bobs ,I like there turkey ,preety good cheers
  2. Dad's (Blue) Tractor
    Look S pretty good to me , I like the blue ones ,we rented a 5000 once and it was really a sweet machine plow 50 acres with it l your dads 8000 loook like he one he neighor had for years , that brings back memories any body know the red numerals on the hood ,what years ? some are white ? Any way pretty sweet
  3. New addition Farmall M
    Wow , that was a good offer , good luck , those rear tires are worth more than that but I can't look at them real close but anyway good for you . i usally squirt sure 2 stroke into the cylinders and turn it over a few times and let set over night and repeat it . 2 or three times . its turning over slow ,the cables are shot with corrosion, replace with 0 or one gage that starter will come alive if you clean commutator like in book recommends any way nice m
  4. New addition Farmall M
    Pretty nice rear tires on it, first thing I look at , your well on your way ,Avanti !
  5. Farmall C Wide Tread Axles
    Your from Ky., that a prime source(area) for wide axle C's . I hear they are for tobacco cultivation I'm told. . I never see them here , I would not cut them as I've seen done . Price is what ever two fools agree on ! as they say !
  6. Yeah, complaining again.
    I was an engineer once and I had do what management told me to do , keep it cheaper than relistic after all of we do what you presented we would all be out of a job πŸ‘ŽπŸΏπŸƒπŸ‘€πŸ€“ got out of the office
  7. Air Compressor Electric Motor Tripping out Breaker
    I finally got it apart the switch contacts for the starter had a lot of black soot and the run side not much I clean both with sandpaper and it the VOM on the can't acts and they have continuity should I take the armature out the armature out the other output side and look for solder, I have a growler but never used it maybe a learning to try it out ?
  8. A few harvest pics
    Give me the keys ! That about all I would say
  9. Snapped three bolts getting the head off of this Tecumseh . Writing this in hopes maybe it will cause you less grief. The Ariens SnoThro engine would run good for about half an hour and start to stall. I had to adjust the needle valve on carburetor as it would run . At night the muffler would glow red. And fire was coming out the exhaust. Hints from other sites suggested valve Clearence . So just before the season I started to in vestigate . I went to remove the head bolts out the aluminum head and block . The motor was cold , The bolts snapped red circled . The one we had to Helicoil, the others threads were saved by putting it on a vertical milling machine and end milled the broken bolt out. So next time I would or say I reccommend try to use map gas torch on the block around the head bolts to get them to expand to help get the bolt to release. Safety first clean oil and remove carburetor. Any way Back the reason ,the exhaust valve I measured with feeler gage to have only 3 or 4 thousands Clearence. , so we reground valve surface and lap them in , to get as close to ten thousands Clearence intake and exhaust. Oh measure the valves on litle past top dead center also to make sure the decompression cam don't inter fear with measuring the Clearence. Let you know how this run in a few days ,,cutting it close ,going to need the machine soo. Im glad I looked into this ,cause the machine had a bearing failure on out pout shaft and the friction drive hub had cracked so in pretty lucky that we got to get this back together before a serious snow comes in off the lake . its a puzzle why that exhaust valve was set that close . I don't remember putting new valve in it . I also wonder if the new gas without lead hammer valve into block , but the valve seat looked good about .05 inch any. That's the Tecumseh story
  10. A few harvest pics
    What is going on there ? John Deere tractor going down in the world of warships, looks like
  11. Member loses barn & cattle last night
    Sad , sorry to hear the bad news
  12. Old working equipment in Decatur TX USA
    I think it's history in action , l like it , good pics
  13. Terrible day! Pictures!
    Wow , congratulations
  14. Thanks for sharing M , I know it will work out.
  15. Deer season opens today...
    We went out this morning , me ,grandson and granddaughter, raining we saw some track and follow them . Don't get close to see them . Had fun , kids they ask the funniest stuff , I almost fell over laugh to hard ,but they got to learn . They set it up , we had rope duct tape and light sabers .
