615 spike
    111
Everything posted by 615 spike
  1. box elder bugs for bait
    I seem blessed with an abundance of box elder bugs. I would like to be able to consider them a resource rather than a pest. Has anyone ever used them for ice fishing bait? They look quite similar to some of the aquatic insects that I have removed from fish innards in the past. I understand that they would be a one bite bait as they are fragile compared to mousies or spikes. thanks cab
  2. Christmas presents for wife
    If you're brave, I suggest the imported 'make America great again' Trumpy Bear. If she is of the liberal persuasion, include a dozen hat pins so it can be used as a voodoo doll.
  3. IH 404 with C135 is haunted~
    When one of my 706's (I have three) acted in a similar fashion, It turned out to be a blockage in the hole that goes to the bottom of the main jet. It took quite a bit of pressure and ether to dislodge it with a piece of wire from a set of guitar strings. Not saying it's your problem, it's just one more thing to check the next time you have the carb apart . cb
  4. Case auger
    Auger looks like it pulls from the ends toward the middle. I'M GUESSING it's for an eight row corn head. cb
  5. IH 303 combine tire size
    I've owned four of them. They arrived here with 14.9-26, 16.9-26, or 18.4-26 tires. all on 8 bolt rims with about a 6' center. They usually end up with 18.4 's as they have better flotation on this swamp I farm. cab
  6. brakes stuck
    not to be recommended , You just disconnect the lines at the bottom of the break controls and cap off the lines to the brakes and the fittings at the bottom of the control valves. If I remember right, Its some kind of jic fitting. Not to be recommended if you are on roads or anywhere near ditches , traffic etc. where you need to stop. Can always cap lines once you get in the field. Also not to be recommended I have loosened up the bolts on my 706 one turn to allow extra clearance for pads. cb
  7. brakes stuck
    Before you start replacing brake parts needlessly, better check to see if the cylinders that the brake pedals control are leaking and allowing fluid through to the brake when the pedal is up. First, check to see if the linkage from the pedal to the control cylinder are set up, rusted, or stiff and that the pedal actually comes all the way up. then crack the lines going to the brake and see if any fluid comes out when the brake pedal is up.(tractor running) if there is an internal link or an improper adjustment of the linkage, fix that first. cab
  8. Skunk in a trap. What should I do?
    The last one I caught in a box trap in someone's front yard, I used ether, aka starting fluid delivered through a ten foot piece of plastic pipe to calm the skunk down. I then covered the trap and hauled it across the road where the skunk went for a under water adventure without it's scuba gear. No smell, not to be recommended where a spark could blow up your porch. cab
  9. If trump got farmers more money
    In answer to Bitty's question on milkweed, the reason for planting it in pollinator habitat is that roundup ready farming has pretty much eliminated it as a common weed, much to the detriment of the Monarch Butterfly . It's a perennial, but a couple of doses of Roundup and its gone. cab
  10. Farmall 560 oil pressure
    You start by checking if the gasket between the filter base and the block matches the channels and ridges on the inside of the base. there are two or three gaskets that are the right size on the outside, but are designed for different filter bases.. I have a 706G that had low oil pressure, reground the crank, installed new bushings on the cam shaft, new bearing -held 25 psi cold with 40 wt oil. put in the correct gasket holds 45psi warm now. cab
  11. 403 combine engine into 806
    I did this with a 706. Assuming your 806 is gas, you pull the front pulleys and swap out the front covers and the plate behind the camshaft gear that bolts to the front cover. This will remove the hydraulic pump that is run off the front of the engine in the 403. front pulleys are most likely different, use the one from your tractor, along with the fan and mounts. At the rear, you will have to swap flywheels. Unless you enjoy pulling engines, NOW is the time to put new front and rear seals on the crankshaft and check to see that the main and rod bearing are good. The exhaust manifolds may need to be changed and the carburetor from the combine draws air from the opposite end and will need to be changed out. The engine usually found on 403 combines is the C263 gas, a sleeveless version of the engine found on 706 gas tractors. Do you really want to make your 806 into a 706? cab
  12. 706 Gas Oil Pressure Problem
    It sounds more like a gauge problem. When worn, the pressure is higher when the engine and oil are cold. AS the oil warms up it thins and the pressure drops. Before you do anything rash, put a mechanical gauge on a new piece of flexible grease gun hose and install it in the hole at the front of the engine on the side with the oil filter and distributor where the sensor or line for your oil gauge goes into the block. If you still have low pressure, then you can play with the spring pressure of the relief valve. cab
  13. 303 combine?
    Yes, the engines are six cylinder engines. The early ones with the front of the platform rounded had BD 220 engines. The later ones with a white front plate had C221 sleeveless engines. After fifty years, it could have almost any IH straight six gas engine in it. C 263 and C301 are a perfect match and more power. cab
  14. 303 combine?
    I have four 303's in my salvage assortment. Two of them I farmed with, bought the third to get the soybean head it had; bought the fourth one to keep it from the scrap man. Things to check : are the tubes on the cross augers rotted out.elevator bottom doors? is the bin bottom in good shape and does the clean out door at the bottom of the unloading auger come off. Was it removed and the bin cleaned after use. What shape are the belts in. I would assume finding a new flat belt would be like finding a unicorn. If the combine isn't cleaned, the shaker pan under the cylinder tends to rot out. The rubber bushings that support the shoe can be quit entertaining to replace and align. Does it come with an assortment of sprockets so you can change cylinder speeds. When you get it running drive it around to see if it jumps out of gear. Does it have a grain head? Is the pittman driving weight tight on its shaft? what shape is the auger in? have the fingers rusted into their balls and pulled inside the tube? I bought my most recent 615 quite reasonably because that happend and it cut the auger in half quite quickly. The owner couldn't find another head. I put on an 800 series feeder house so I could run more modern heads (modern being a relative term) good luck cab
  15. 715 combine
    Make sure you get all the parts you need. The feeder house takes longer cylinders, the brackets the feeder house pivots in are needed, the little brackets for the door above the feeder house are needed, also needed is the door at the top and the thingy that pivots just above the feeder house (it has the belting that seals the top attached. You will also need the hinged rock trap thing that goes underneath to seal off the bottom side of the feeder at the top end. cab
  16. elm for fiewood
    I like to burn elm. I cut them after they die. There is a stage after they lose their bark where the wood take on a yellowish cast. I call it golden elm. almost like burning charcoal-long burn time, nice red coals, plenty of heat. Green and damp or dead and starting to get rotted, not such a good product to burn. Two years drying would be better. cab
  17. IH 403 D301
    The 403, 715 and others from that era have brackets that bolt to the separator clutch housing and to the top sides of the separator. If I remember correctly, the brackets at the fan end attach to the front cover and to the top side of the separator on that side. The top of the separator extends about two inches beyond the sides and has a reinforcing layer. This is where the 5/8 bolts that hold the bracket go through. cab
  18. I had my faith in Americans restored Friday
    Why is the song 'Thank God and Greyhound your gone " now going through my mind? cb
  19. IH 2544 Wheel Wobble
    There are about three possibilities. The tire rim is bent, the bearings in the hub are bad. or the top of the spindle is moving independent of the arm attached to the top. Step one, jack up that tire so it is off the ground. Grab tire and rock side to side. If the hub moves on the spindle, you need bearings, If the bearings are all right, spin tire and watch for wobble. A bent rim will wobble in and out at the same place each time the tire rotates. If that all right, try to turn the wheel by hand and see if the center of the spindle moves in the control arm. If it does, many of them have been tightened with JB weld, welding, or tightening the fastener at the top of the spindle. hope this helps, cb
  20. Stuck Clutch on 715 Combine
    There is no inspection window. It isn't that difficult to do it right. If it got that flooded, you should probably drain and refill the transmission, pull the clutch housing so you can check the throw out bearing and the springs that retract it, along with cleaning up the splines and outer bearings on the clutch shaft. Start by putting transmission in neutral, lower header to ground, move variable speed pulley to slow forward speed. shut off engine, climb down, tie ladder up out of the way, jack up front of axle until you can remove drive tire under the platform.Crawl under and unhook spring and turnbuckle that go to the clutch lever. block up securely and remove tire (my electric impact wrench makes this a lot easier than it used to be). With tire removed, release tension on the variable speed pulley belt. Either loosen bolt or brace a 2by 4 between tension arm and frame. remove the bracket that adjusts the variable speed at the front by loosening the long threaded eye bolt that adjusts it and remove pin from eye. then pull bolt (15/16 wrench) from its end and the two half inch bolts that hold it on. Remove nut from clutch shaft. the outer part of the variable speed pulley should now come off. remove. move belt out of the way and remove the idler pulley and arm from the shaft that attaches to the clutch housing. remove the rest of the variable speed pulley and you are down to the clutch housing. The housing is held on by a bunch of 3/8 bolts around the outside, a couple of which will test the flexibility of your joints, but not impossible. When bolts are all out, wiggle and pull until it comes. If things are frozen badly, a pry bar or two may help. when off, check all bearings shafts plates springs etc. assembly is the reverse. Far better to spend a few hours making sure things are right than to have clutch fail to release later when you might really really need to stop. cab
  21. 303 / 615 combine header search
    I have seen only a handful of 10 ft 810 grain heads advertised in the last dozen years, they are about as scarce as my 833 three row narrow corn head. Most of the 810's in that size were equipped with windrow pickups, I suppose with enough work and a larger parts head you could convert one in a few days. I run a 13' 810 on my 615, I have run a 15' hart carter 810 on it, but it picks up the rear end if you raise the header fast (scary, but it works real well to get the dirt off the cutter bar). The smallest 820 I think I've seen is 13 ft. They tend to have a hydraulically driven reel which neither of my 615's are set up for. you can try a nationwide Craigslist search to locate a head. cb
  22. Ih 303 combine
    The person I bought my 615 feeder house from hauled his 615 by backing it onto a car dolly and hauling it backwards at upwards of 40mph. I suggest if you have to travel a long ways to check the fluid level in final drives and transmission first. If it's in good shape, you can just drive it home. shouldn't take more than ten hours and a couple tanks of gas. cb
  23. Fast Hitch Planter build
    A couple AC no till openers or a fertilizer set up on the front bar would eliminate the need to build stands to set the planter on and serve to make it a more versatile planter. cb
  24. our farms adjoin each other in various places, I live 1.3 miles north and 1 mile west of him. I'm at 8321 Satterlee Rd. cab
  25. Feel free to arrange a visit to my iron pile located west of the barn with built in twin poured silos located at the sw1/4 of section 20 cato twp. charles Behrenwald
