Bleedinred
    1,229
About Bleedinred
  • Birthday 02/12/1951
  • ICQ
    Juliaetta, ID
    Family, fly fishing, back country skiing, old machines,
596 profile views
  1. 826 with a 358D engine overhaul
    Pete 23 knows the 358 bolt specs forward and backwards, he's the guy to talk to. Been a few years but I think we found rod bolts from a local dealer as ARP couldn't supply, seems like it was around $240. If you do not replace those rod bolts you will probably regret it later on.
  2. New! We don't even know what new means!!! 503 & 403 combines
    Ray, modified 715. Hydros in diesel or a gas dog. Same tranny, leveler and basic frame as the 403H.
  3. Japan surrenders
    My dad applied for Navy sonar school just before he graduated from HS when he was 17 but didn't get in, so he enlisted in the Army at 18 and did his basic at Ft L Wood Missouri. He was a BAR man and was destined for Japan until the bombs were dropped. He ended up a radio operator in Austria for a year and by that time it was all over. The Mo was moored in Bremerton, WA for a number of years with very limited touring. As I remember you could see Captain's ward which served as a small museum and once or twice a week very limited tours were offered below deck for a fee. We took the kids three different times before it was eventually refitted and served in the Gulf War. If I remember right that was the only wartime duty the Missouri saw before returning to Bremerton and eventually being towed to Pearl.
  4. Power shifting
    Thanks for posting that Mark. A stock '67 RS Camaro driveline won't take that abuse. It's a long walk back to pick it up off the road in the wee hours of the morning I was reading Hot Rod mag long before I got my first car, a '55 Bel Air. I was 14 then but neither the car or I were chick magnets...
  5. 1206 prices??!!
    OK, got the JD thing off my mind and will contribute my brief 1206 story. September 1969, I was in charge of getting a vehicle to pull our JR class float in the homecoming parade. Got a classmate to do it but he had to cancel at the last minute. Clock is running, remember the neighbor I helped in the summer just traded his 806 off for a new 1206 at Fountains IH in Beresford, SD. Drove out to the farm where they were cutting silage--1206 in shed, 4020 on cutter! Yes, he said, go ahead and take it to town, and what a sweet ride that was. Got her hooked up to the float but I was in the marching band and couldn't drive it so my buddy got a quick shifting lesson and away we went. Still trying to find a picture of that tractor all shined up with 2 hours on the meter. By the way, the 806 was bought back and I put many summer hours on both of those tractors.
  6. 1206 prices??!!
    Cough, cough...the bit in the JD book about the 5020 replacing crawlers out here in the PNW is pure BS. There was and is NO two wheel drive tractor that could manipulate these hills equivalent to a track layer. That's my opinion and I'm not humble about it.
  7. 3 point plow settings
    As you can see in the picture your offset should be rotated 180 as was mentioned. Definitely lose the chains.
  8. Plastic gas tank repair
    PTex? Light well away from the tank, blow out, then smear it on.
  9. 3 point plow settings
    Changing the offset will increase or decrease width of cut and plow will not draft correctly. I would buy or make two adjustable links. I have one of those plows and it works really on my TO 30 for garden work. Need files of the manual?
  10. 56 series diamond cab vs 66 series cabs
    You could order a 66 series tractor with the custom cab. A neighbor had a 1456 with that cab, traded in 1972 I believe, for a new 1468 and got same cab. I preferred it for vision,doors and the steps. It was real easy to add AC to those, been there done that.
  11. 1066 using 1 gallon of coolant per day
    This won't answer your coolant usage question but pertains to a similar heating problem. JD 466 combine engine--changed thermostats twice, then belts, then both hoses. Finally swapped out the reman water pump that was replaced before harvest started and end of problem. Tore down the "old" newly reman pump to find the impeller was slipping on the shaft. Coolant loss was out the overflow tube. Are you having any loss there?
  12. Tinnitus
    "If wives know you have a hearing loss they talk quietly so they can complain about you not hearing them." Boy Dennis, 10-4 on that. I bought $1,700 hearing aids from Costco and I still can't understand what she says most of the time.
  13. Help engraving my stove door?
    "what is the purpose of the upright gate valve shown in your 2nd picture???" --Ether injection port for startup!
  14. This set up is someone else's fix for the dusty conditions out here in the Palouse. I'm going to go back under the hood and not use the precleaner cup if I can. I bought an 856 housing and pipes but found out the early 856's used the same single stage set up as the 806's. I might be able to fit this Donaldson under there. Dad put a Turbo on his 856 and was pretty happy with it. Back in the day just about every combine in our area had a Turbo precleaner.
  15. 12 fires in Montana
    MTO and others, get on a PNW fire map and see what else is going up in smoke. It's not just Montana but all over this area. Here south of beautiful Juliaetta, ID we had the worst air quality in the nation for a couple of weeks. We have been getting it from Oregon, WA, BC and east of us out of the Bitterroot Mtns all the way to Missoula. Normally dust and smoke did not bother me in my younger years but lately Mr.Inhaler and inside living have been my friends. Mader, praying for rain for all of us. Last one here was the first week of June. Agree on the enviros--don't have a clue. Was in Seattle last week and read of more efforts to reintroduce grizzlies in the N Cascades. Good deal, the weekend city hikers will make good feed for them. Putting my complaints aside, we have not burned, flooded or been blown away this year here in the Lewis-Clark Valley.
