Az.Nick
    507
About Az.Nick
    http://colombohome@gmail.com
    Waddell, Az.
1,403 profile views
  1. MM that came out nice, as usual! Nick
  2. Great point WL, will know soon, when I get it opened up. Thanks for the reply. Nick
  3. Thanks for the replies. I was working Rex at the time of the issue, pushing dirt and all of a sudden "pow"! I was up about 3/4's on the throttle and not sure if there is a limit I should of been maintaining, doesn't have an RPM gauge! Grabatire, is my 282 considered a 660 series or? I'm currently soaking the parts motor, due to it being stuck and hope to pull its crank as a fix. Nick
  4. Well now that its over 110 degrees here, I thought it would be a good time to handle some iron! I got Rex up on the slab last weekend and pulled the pan and MM your correct, I have a two piece crank at the #6 bearing. That explains the heavy shacking at my feet. I made the decision to pull the motor and do it right. If you remember the engine was the only thing that we didn't touch during the restore, so going to bring it up to speed. If you have any suggestions moving forward, I'm all ears. I do need a good reference on parts for bearings & possibly the engine rebuild kit/part #? I dug out the later spare 282 motor for parts and need to look at the crank and head. Will the crank part #'s be the same if the engine block #'s are the same? I remember reading a topic on the later heads having bigger valves. I'm thinking of swapping out the heads, being the engine part #'s are the same. I will post to that conversation to share the info. Thanks, Nick
  5. So whats the verdict JC did you find the parts? FYI I have the manual for the 9K3 if every needed! Nick
  6. Looks great, send work pics? Nick
  7. Nice dozer TG, your talking to right guys, keep us posted & good luck! Hi boys, hope all is well and glad to see guys are popping back into RP life Nick
  8. Ron, much agreed on the rest start, I think I got of lucky on not getting any new inspection holes in the block. It was a workout for the Ford 4500 backhoe to herd Rex back to the shop. Its was like Chihuahua pushing and elephant in a deep sleep and the corners were a bear! MM- I'm think'n your suspicion might match what I felt in the main frame. I'm glad I took your advise and purchased the parts machine for a rainy day . I definitely have a new years resolution/project to fulfill...... Nick
  9. Thanks for the feedback guys. Need to free up some garage space and get a look at it. Maybe I didn't put enough emphasis on the vibration, it felt like the engine was trying pass through the clutch compartment. One of those moments that brings all hands, ear's, & eyes on deck, and you say "That's Not Good" . What other possibilities could it be with the loss of oil pressure, that's why I was leaning toward the bearings? Nick
  10. Guys, I'm seeking advise and gearing up to dive into Rex's engine issue, which I believe is at least a spun bearing. As I mentioned in my post awhile back, I was working Rex and developed a horrible vibration/shaking at my feet on the main frame. I immediately lost oil pressure and engine started to lope heavily before shutting down. All the other gauges read in the normal range at the time. I tried to turn it over with no fuel one time after the shut down, and the vibration was present on tune over. To my knowlege this 282 has never been rebuilt. The engine case is intact from the best I can tell. I've looked over the archives for posts on lower end issues and didn't come up with any matches. I welcome any links or advise on this issue. I've never been in the D282 engine on this machine. Is this something that be done in frame or does it need to come out? What are the main points to look for and the nessary steps I need to keep in mind? Thanks in advance, Nick
  11. Good to here from you and welcome back to Az.Tom. I was at the property in Skull Valley last Sunday and went through P.V. looking for you place, where are you located again? I have plans to cut a driveway into the property, which has a few challenges due to the slop and 60' grade difference from the road to the property level. I purchased an angle blade for Rex, which pins in place of th...
  12. Hello, are you still kick'n?
  13. R59 just checking on how are things coming on the 12, and I hope work is good for you.
    Nick
  14. has not set their status
  15. This list has been put together by a few RP memebers to help you find IH parts & service providers, that are frequently asked about. PM me new info and I will update it as needed. Updated: 6-17-10 Roberts Tractor- Ohio (800)367-8751 WWW.ROBERTSTRACTOR.COM (over 4k dismantled machines lists: TD6 & 9, T340, Cub Cadet, and all wheeled machines. Greer Aftermarket Parts- Jon 602-541-5971 (if you have a part #, make, model he can find it) greerparts@hotmail.com http://easybobstract...s.com/index.php http://www.tractorparts.com/ http://www.tractorda...m/td/index.html http://www.ytmag.com...md=T-6+and+TD-6 http://www.bmcdowell...dismateling.htm http://www.paccarwin...amp;littype=MTL P&D Mechanical. www.pdmechanical.com 315-559-4992 Justin Weber. www.ihparts.com. 570-434-0876 F.P. Smith Co. www.fpsmitheq.com 800-55TRACTOR Ed @ CrawlerHaven.com Brown International. www.brownihc.com. 250-546-6518 Biewers. www.salvagetractors.com. 218-493-4696 General Gear. www.tractorparts.com. 208-342-8911 Crawler sites. www.hcea.net All types & brands of Construction Equip. www.ibdozing.com http://oldihc.org IH Trucks. www.schaeperkoetter.com Check out this place! http://irontrader.com Lots of old iron for sale. (subscription) Free looking www.centralfuelinjection.com Serial#'s http://www.castofthe...%20Crawlers.htm http://www.ytmag.com...kup.cgi?mf=INTC http://www.oldoakfar...HCNebTable.html Manuals/Decals http://www.binderbooks.com/crawler.htm http://www.jensales.com/manuals.asp http://www.antiquefa...literature.html (some downloadable manuals) Undercarriage specs http://www.crawlerheaven.com/ http://www.scarlett....l#International Filters http://baldwinfilter.com/ http://www.wixfilters.com/ Parts http://www.napaonline.com/ http://www.brownihc.com/ http://www.blountparts.com/ http://www.dura-tuff...grouserbars.asp http://www.hastingsmfg.com/ http://www.partsfind...ozer/page1.html http://www.bmcdowell.com/Default.htm http://www.wengers.c...ction-parts.asp http://www.westwardparts.com/ http://www.ceparts.com/ http://www.jobbersinc.com/ih.htm http://www.minnpar.com/ http://www.elbex.go3.pl/ http://www.powermaxparts.com/ http://www.tractorparts.com/ http://www.pdmechanical.com/ http://www.ihparts.com/ http://www.batescorp.com/ http://www.fpsmitheq.com/ ----------------------------------------------------- Power Twist V Belts http://www.grainger....ger/items/5A548 TD9 Power Twist V Belts http://www.mcmaster.com/ ----------------------------------------------------- Thermostats http://inpcars.com/t...ostats1/20.html Stant 13436 for TD18 Same as NAPA 33038 ------------------------------------------------ Radiators- new rad cores http://www.generalradiator.com/ ------------------------------------------------ Main clutch/flywheel http://www.uniqueclutches.com/ Unique Heavy Duty Clutch Rebuilders 693 West Booneslick Road Jonesburg, MO ----------------------------------------------------- Steering clutches, brakes, finals, etc http://stores.ebay.com/Murphy-Tractor http://www.steeringclutch.com/ ----------------------------------------------------- Magnetos http://www.farmallmagneto.com/ http://www.standardmagneto.com/ http://www.mainelyma...ernational.html Weitzel's D.C. Electric Norwalk, Ohio 419-668-2844 ----------------------------------------------------- Starters - Generators http://www.suncoastp...m/products.html http://mad-parts.com...ctID=140%2D9877 ----------------------------------------------------- Carbs http://www.thecarburetorshop.com TheCarburetorShop Eldon,MO tech@thecarburetorshop.com (573) 392-7378 Zenith carb parts+ http://www.carbsonly.../indandfarm.htm (mainly ag) http://www.oemtractorparts.com Kit is listed as F-8 carb repair kit #OEM32581DXB. Fits TD6 and TD9. http://www.daytonaparts.com/ ----------------------------------------------------- Injection Pumps and parts http://www.owossotractorparts.com/ Owosso Tractor Parts & Equipment - Michigan (888)530-4554 http://www.centralfu...rnationalH.html Central Fuel Injection, Sioux City Iowa, 1-800-548-9464 http://www.usdieselparts.com/ US Diesel Parts, Missoula MT. http://www.jobbersinc.com/ih_inj.htm IH pumps repair and parts AG west in Junction city, or Harrisburg (Oregon?) has a pump man that specializes in the old IH pumps, and has parts for them. ----------------------------------------------------- Hydraulic pumps and parts Associated Tractor Stockton, CA http://www.associatedtractor.com (209)466-3003 (800)735-1301 IH & BeGe pump parts, $unknown, bege pump kit $100 ----------------------------------------------------- Manifolds http://www.tractorpa...t_manifold.html (Old gas tractors) ----------------------------------------------------- Light bulbs http://www.candlepowerinc.com/ Light bulbs of all kinds. ----------------------------------------------------- Decals http://www.QuipCal.com http://www.associate...pmentDecals.php ----------------------------------------------------- Cylinder head repair Chapin Cylinder Head Repair in Chapin IL. They used the plug method of crack repair.~$300 per head. Came with a warrenty that could be extended for a fee. My contact info is a few years old. The phone # I have is 800-843-1245. Midwest Cylinder Head repair in Nevada, IA. Mid West Cylinder Head Nevada Iowa 515-382-2791 ----------------------------------------------------- Gaskets, engine parts http://www.weberstractorworks.com/ Olsons Gaskets Orchard, WA http://www.olsonsgaskets.com (360)871-1207 (International calls use country code 011) Engine gasket kits,pony head gaskets,etc ,real reasonable Hours of Operation: Monday - Friday 8 -5 (PacificTime) E-Mail: info@olsonsgaskets.com ----------------------------------------------------- Bearings http://www.Daltonbearing.com Keith@Daltonbearing.com (Searches to find old bearings, good price too) ----------------------------------------------------- Button head fittings for track rollers http://www.alemite.com/ http://www.alemite.c..._standardbutton ----------------------------------------------------- Used IH crawler parts yards hector gemme <gemdozer@hotmail.com> Clapp Bros TD9,TD14,TD14 142,TD18,TD18 182,TD25 250 SERIES PLUS OTHER INTERNATIONALS FOR PARTS. LOCATED IN CENTRAL ILLINOIS ,PHONE 217 967 5219 OR E-MAIL ac7gb@webtv.net cox heavy equipment in granby mo has several 18s for parts. FP Smith - Selena, CA (707)864-1122 Kugler Salvage - Fergus Falls, MN (800)874-2130 Thill Track and Tractor - Eau Claire, WI (715)832-2128 General Gear - Idaho (800)531-9021 Schaefers Enterprises of Wolf Lake, Inc. - Illinois (618)833-5498 Kronig Tractor in Amity, OR 503-835-2011, Eric An IH crawler "resting" yard of sorts.....tons of used parts Cooper Tractor in Portland, OR 503-252-1198, Aaron Good place to get new engine parts. If they are available, these guys will do whatever it takes to find them. Fair prices and shipping is no problem. Crawler/Dozer/Tractor/Websites. Bearings. http://web.applied.com/ http://www.e-webcata...ataloglook.aspx http://www.kamandirect.com/ http://www2.chicago-...okup_457012.htm http://www.mfpseals.com/ Bearing Belt & Chain http://www.bearing.com/home/ http://www.bearingbeltchain.com/ Parts http://www.drapertractor.com/ https://www.motionin...p/mi/motion.jsp www.salvagetractors.com. Biewers. 218-493-4696 NAPA catalog search http://www.napaonlin.../...&ShowPics=1 http://www.tractorho...asp?CID=2933561 Bates corp. http://www.crawlerheaven.com/index.htm http://brokentractor.com/request.htm http://www.sewlparts.com/ www.pdmechanical.com P&D Mechanical. 315-559-4992 http://www.trackroller.com/ turbo’s. Links #’s to other Az. businesses. http://www.tksimplex...ml/arizona.html Crawler sites. www.hcea.net All types & brands of Construction Equip. www.ibdozing.com http://irontrader.com Lots of old iron for sale. (subscription) Free looking. Undercarriages- http://www.trackroller.com/ Red power- info forum-great people. http://www.redpowerm...ine.com/forums/ PAINT http://www.wisconsin...ives/ihc/paint/ Haulers http://www.tractorho...enthauling.aspx Misc. http://www.grainger.com Nick.... ---------------------------------------------------------------------------- Serial#'s http://www.castofthe...%20Crawlers.htm http://www.ytmag.com...kup.cgi?mf=INTC http://www.ytmag.com...md=T-6+and+TD-6 http://www.oldoakfar...HCNebTable.html Tractor specs http://www.tractorda...m/td/index.html Manuals/Decals http://www.binderbooks.com/crawler.htm http://www.jensales.com/manuals.asp http://www.antiquefa...literature.html (some downloadable manuals) http://www.QuipCal.com http://www.associate...pmentDecals.php Undercarriage specs http://www.crawlerheaven.com/ http://www.scarlett....l#International Filters http://baldwinfilter.com/ http://www.wixfilters.com/ Parts http://www.napaonline.com/ http://www.brownihc.com/ http://www.blountparts.com/ http://www.dura-tuff...grouserbars.asp http://www.hastingsmfg.com/ http://www.partsfind...ozer/page1.html http://www.bmcdowell.com/Default.htm http://www.wengers.c...ction-parts.asp http://www.westwardparts.com/ http://www.ceparts.com/ http://www.jobbersinc.com/ih.htm http://www.minnpar.com/ http://www.elbex.go3.pl/ http://www.powermaxparts.com/ http://www.tractorparts.com/ http://www.pdmechanical.com/ http://www.ihparts.com/ http://www.batescorp.com/ http://www.fpsmitheq.com/ http://easybobstract...s.com/index.php http://www.paccarwinch.com http://www.drapertractor.com/ https://www.motionin...p/mi/motion.jsp https://www.salvagetractors.com Biewers. 218-493-4696 http://www.napaonlin.../...&ShowPics=1 NAPA catalog search http://www.tractorho...asp?CID=2933561 Bates corp. http://www.crawlerheaven.com/index.htm http://brokentractor.com/request.htm http://www.sewlparts.com/ https://www.pdmechanical.com P&D Mechanical. 315-559-4992 http://www.trackroller.com/ turbo’s. --------------------------------------------------- Links #’s to other businesses. http://www.tksimplex...ml/arizona.html ----------------------------------------------------- Power Twist V Belts http://www.grainger....ger/items/5A548 TD9 Power Twist V Belts http://www.mcmaster.com/ ----------------------------------------------------- Thermostats http://inpcars.com/t...ostats1/20.html Stant 13436 for TD18 Same as NAPA 33038 ----------------------------------------------------- Main clutch/flywheel http://www.uniqueclutches.com/ Unique Heavy Duty Clutch Rebuilders 693 West Booneslick Road Jonesburg, MO ----------------------------------------------------- Steering clutches, brakes, finals, etc http://stores.ebay.com/Murphy-Tractor ----------------------------------------------------- Magnetos http://www.farmallmagneto.com/ http://www.standardmagneto.com/ http://www.mainelyma...ernational.html Weitzel's D.C. Electric Norwalk, Ohio 419-668-2844 ----------------------------------------------------- Starters - Generators http://www.suncoastp...m/products.html http://mad-parts.com...ctID=140%2D9877 ----------------------------------------------------- Carbs http://www.thecarburetorshop.com TheCarburetorShop Eldon,MO tech@thecarburetorshop.com (573) 392-7378 Zenith carb parts+ http://www.carbsonly.../indandfarm.htm (mainly ag) http://www.oemtractorparts.com Kit is listed as F-8 carb repair kit #OEM32581DXB. Fits TD6 and TD9. http://www.daytonaparts.com/ ----------------------------------------------------- Injection Pumps and parts http://www.owossotractorparts.com/ Owosso Tractor Parts & Equipment - Michigan (888)530-4554 http://www.centralfu...rnationalH.html Central Fuel Injection, Sioux City Iowa, 1-800-548-9464 http://www.usdieselparts.com/ US Diesel Parts, Missoula MT. http://www.jobbersinc.com/ih_inj.htm IH pumps repair and parts AG west in Junction city, or Harrisburg (Oregon?) has a pump man that specializes in the old IH pumps, and has parts for them. ----------------------------------------------------- Hydraulic pumps and parts Associated Tractor Stockton, CA http://www.associatedtractor.com (209)466-3003 (800)735-1301 IH & BeGe pump parts, $unknown, bege pump kit $100 ----------------------------------------------------- Manifolds http://www.tractorpa...t_manifold.html (Old gas tractors) ----------------------------------------------------- Light bulbs http://www.candlepowerinc.com/ Light bulbs of all kinds. ----------------------------------------------------- Cylinder head repair Chapin Cylinder Head Repair in Chapin IL. They used the plug method of crack repair.~$300 per head. Came with a warrenty that could be extended for a fee. My contact info is a few years old. The phone # I have is 800-843-1245. Midwest Cylinder Head repair in Nevada, IA. Mid West Cylinder Head Nevada Iowa 515-382-2791 ----------------------------------------------------- Gaskets, engine parts http://www.weberstractorworks.com/ Olsons Gaskets Orchard, WA http://www.olsonsgaskets.com (360)871-1207 (International calls use country code 011) Engine gasket kits,pony head gaskets,etc ,real reasonable Hours of Operation: Monday - Friday 8 -5 (PacificTime) E-Mail: info@olsonsgaskets.com Cooper Tractor in Portland, OR 503-252-1198, Aaron Good place to get new engine parts. If they are available, these guys will do whatever it takes to find them. Fair prices and shipping is no problem. ----------------------------------------------------- Bearings http://www.Daltonbearing.com Keith@Daltonbearing.com Searches to find old bearings, good price too. http://web.applied.com/ http://www.e-webcata...ataloglook.aspx http://www.kamandirect.com/ http://www2.chicago-...okup_457012.htm http://www.mfpseals.com/ ----------------------------------------------------- Bearing Belt & Chain http://www.bearing.com/home/ http://www.bearingbeltchain.com/ ----------------------------------------------------- Button head fittings for track rollers http://www.alemite.com/ http://www.alemite.c..._standardbutton ---------------------------------------------------- Undercarriages- http://www.trackroller.com/ ----------------------------------------------------- PAINT http://www.wisconsin...ives/ihc/paint/ ----------------------------------------------------- Haulers http://www.tractorho...enthauling.aspx ----------------------------------------------------- Misc. sites. http://www.grainger.com ----------------------------------------------------- Used IH crawler parts yards hector gemme <gemdozer@hotmail.com> Clapp Bros TD9,TD14,TD14 142,TD18,TD18 182,TD25 250 SERIES PLUS OTHER INTERNATIONALS FOR PARTS. LOCATED IN CENTRAL ILLINOIS ,PHONE 217 967 5219 OR E-MAIL ac7gb@webtv.net cox heavy equipment in granby mo has several 18s for parts. https://www.hcea.net All types & brands of Construction Equip. https://www.ibdozing.com http://irontrader.com Lots of old iron for sale. (subscription) Free looking. FP Smith - Selena, CA (707)864-1122 Kugler Salvage - Fergus Falls, MN (800)874-2130 Thill Track and Tractor - Eau Claire, WI (715)832-2128 General Gear - Idaho (800)531-9021 Schaefers Enterprises of Wolf Lake, Inc. - Illinois (618)833-5498 Kronig Tractor in Amity, OR 503-835-2011, Eric An IH crawler "resting" yard of sorts.....tons of used parts http://www.bmcdowell...tling_Parts.htm ------------------------------------------------ For the DowNunder boys: Track repairs and reconditioning. http://www.trackex.com.au/ - at Toowoomba and Mackay, Queensland. http://www.eyresmith.com.au/index2.htm - Metford, New South Wales. ------------------------------------------------ To jump to link old topic: http://www.redpowerm...d...36122&st=20 Nick
