Allen Ulmer
    17
About Allen Ulmer
  • Birthday 03/18/1983
    Menno, SD
339 profile views
  1. Last ride for 2017! KS State Fair
    Take a last ride for 2017! We were in Hutchinson, KS last Sunday afternoon for the KS State Fair. This is the last run for this tractor and it was a great one! From the drivers seat From the sideline
  2. How warm do you keep your house?
    Shop is 60 in winter, 75 in summer. House 75 in summer, 65 in winter.
  3. 2016 Ne Bush Pullers banquet
    Must have been my vote that put you on top! Lol!
  4. Automotive AC Technicians, Any Help Here?
    You sure it's not the high speed fan relay that's burnt out?
  5. Interesting Pulling video.
    Most top of the line Pro stocks are 125mm + intake wheel turbo setup. If they are running an aftermarket crank, block, rods, pistons, sleeves, timing gears, cylinder head, camshaft, valve train, etc. You're looking at a easy $60,000 motor setup and many are much more than that.
  6. Last Call :)
  7. Last Call :)
    https://m.facebook.com/story.php?story_fbid=10205701175955050&id=1424646206
  8. What size for a homeowners shop
    If a guy can dream..... 60' x 200' x 18' side walls The first 40' would be my house & garage..... The rest of the 160' would be the shop..... Dream over....
  9. Homemade engine stands
    Used a gear box off of an irrigation unit, as you guys previously had stated. I believe it's off of a Zimmatic. The base is 2" x 4" x 3/16" tubing, the upgright tube is 2" x 4" x 1/4" tubing and also had to add a piece of channel iron on the back to keep it from bowing. Can turn the motor over very easily with the hand crank. Used some 1/2" thick plate for the castors and for the mounting plate for the engine.
