MinnesotaFarmall
    422
Everything posted by MinnesotaFarmall
  1. L170 nh skid steer
    Hello guys, I figured this is the place to ask besides the tech forum. We have a new Holland l170 that just flat out died on us like someone just shut the key off. I've gotten my hands on this gal quite a bit and am pretty confident on how it works. This time I'm really stumped. When you sit in the seat, computer says acc, should just light up and show hours. Then put on the seat belt, no change (normal) and lastly, if you turn the key to start, it only will crank it over, but computer says acc and doesn't change anything else. (Not normal). It should show glow on the meter and should kick the fuel pump on, does none of this. The computer is fairly new as we had it go out once about two years ago, so I think it seems fairly early for it to go out again... But, I'm starting to think it's the computer again, it's fairly expensive and I would hate to though it on to say hahahaha in my face. I've already changed the key switch and it is sending power out on the posts it needs to. Does anyone know how the electric system works on this? Anyone have a diagram or had this problem before?
  2. L170 nh skid steer
    I finally found the culprit guys. It was a bad connection in the fuse box behind the firewall. No need to buy a new computer or do any major wiring. It would light up my test lamp, but it wouldn't hold a light bulb. Problem solved!
  3. L170 nh skid steer
    Nope not the same fella. That is a bad deal too. He lived, just has a bad leg now.
  4. L170 nh skid steer
    I'm not a fan of bypassing stuff. Just a couple weeks ago a kid caught his leg between the ski loader bucket and the tire. He went to climb up in and slipped, he grabbed the lever and it sucked his leg right down between it. I know for a fact he had the seat belt bypassed, so it's not going to happen. I'll gladly spend the money on safety switches, it's simply not worth getting hurt. All of your safety switches work.
  5. L170 nh skid steer
    Yea we used to get that until they are swamped, then it's here is the info you need buy your parts here haha. We have done business there for twenty something years, so they know us well and we treat them to a bone or two.
  6. L170 nh skid steer
    Thanks for your reply, sorry just seen it. I will check it out!
  7. L170 nh skid steer
    I am absolutely certain that I have no bad wires on module, and that I got them on the key correctly. It all worked flawlessly up till it went bad (obviously haha.). I hope I don't sound arrogant, because I'm not, I have over looked the obvious a time or two, but this one has got me stumped. If I had a wiring diagram I could read it. I've been working on machinery for five years now with three years of schooling under my belt (doesn't mean I'm the brightest on the tree). I just don't know what sensors are hooked to it besides the seat and the belt. It will run the fuel pump but it just isn't opening up the shut off solenoid. I'll probably have to wait till Monday and call our local dealership, they usually help me out without hesitation. It could be a trouble code of some sort, as it does have a diag port right behind the computer too. This one doesn't have an override either if that makes a difference.
  8. L170 nh skid steer
    It will not turn over unless you are sitting in the seat with the seat belt on, which that is the normal operation also. It will crank the engine, but will not unlock the hydro or anything else. The computer should not read acc unless the key is in the acc position, but I get it in every position but off. Which is very abnormal, so, in respect to your answer, the safeties are all functioning as they should, as that's why I am thinking the computer.
  9. Thieves
    If using trail cameras, always put one on the camera you are using to catch them. Sometimes they see the cameras and take them, but not the other. Now you have them on camera actually stealing property.
  10. Hired Grain Haulers
    Well come this Saturday, she'll be my wife, but she already helps. Doesn't disk, or nothing big, but will move the truck, skiddy or other implement in the field for me to the other end. Bring a truck load of fertilizer, or do what I ask, as long as she is comfortable with it. Don't push, she'll warm up to it.
  11. 1937 Pontiac engine
    I have a 37 Pontiac with flat top inline engine. Shows potential for a resto project. I got it from previous owner who says it was just a little stuck, didn't take much to get it free. Long story short it has everything needed to run, minus compression. It is around 50-55 across the board. I'm thinking that the rings are just stuck and need some freeing up. Just want to make sure it at least will sputter. Going o take a chance and pour some Diesel down the cylinders to get the rings free. Do you guys have any other opinions?
  12. 1937 Pontiac engine
    Sweet guys, sorry I haven't seen the topic pop back up in the section. We ended up stumbling upon an engine. A guy who we got some cows from had one that he rebuilt in highschool. He is retired now, so it's been sitting... But still is very nice looking and all the ports are covered. Best part was, it was free.
  13. Wisdom of buying an Elwood axle to farm with?
    We have several with the Elwood on our 86 series. If they are set right, turning wise, they really aren't that bad. No you can't turn as sharp as a normal front, but hey, when you hit that we spot, a regular front end isn't going to help you much, if any. The other big advantage is just getting the power to the ground, I don't care what anyone says, with two wheel drive, you're spinning. I have brand new Agri bib tires on my 1066, pulling a 5x18 710 plow, you spin even in first high. The front end helps a lot in spinning and puts the power to the ground. Less fuel consumed, more money in your pocket.
  14. Great run today
    Who put it in the weeds? Also I'm sure everyone wants to know too, why is your gauge covered?
  15. Same rant, different day.....
    Biggest thing is that people need to say, "it's the past, get over it." This country was basically formed on a dream. Everyone felt as if they were being discriminated against and they simply picked up and moved. There are other places to be. Everyone will always get their feelings hurt no matter where you go, there is always that one person who is willing to offend or defend themselves over anything, I mean anything. These protesters are nothing more than a bunch of hoodlems that have their feelings hurt over the past. There were slaves in the Bible even. Fact of the matter is that isn't happened, is it happening to you? How? Where? Why? Is someone being mean to you? How where and why? Maybe if no one has anything nice to say about you, then there is someone else who needs to change, not society. Thank you for listening, I'm out.
  16. Rough Start / Misfire at high Idle
    Awesome glad you got it figured out. The cap should be vented. Maybe time to replace it?
  17. Funny noise in my new to me M-TA Thought is was an axle bearing, but...
    Wow, now that is neat.. I would definitely put them up on the shelf. How many people can say they have them?
  18. Can a D361 be made bigger?
    As far as I know they are different. But with some machine work and some time, I'm sure it could be done...
  19. IH 886 with German diesel
    As far as parts however, there are more German diesel in our wrecker yards than there are the 360 engines.
  20. IH 886 with German diesel
    We have one in our 886. It does what we ask of it, spreads manure, blows the silos full. It's nothing compared to our 766 with the 360 though. It seems as if it has more power and tourque. The 358 is good, no doubt, the 360 is just slightly better.
  21. Today`s misinterpretation
    Reminds me of a deal I seen on YouTube I think. Have to buy just three items any three to get the cashier to ask what you are up to. One guy got cake mix, a sympathy card, and rat bait lol.
  22. 3 Tri Stripe 86's in a row to be sold.
    Where is that?
  23. 686 engine swap
    Good deal. I had my starter custom built at a shop local here. It was a third of the cost as one from a.i.
  24. 686 engine swap
    Of course I forget the starter. The d301 is a whole different can of worms for part numbers and such. The 686/666 use the same parts however
  25. Rough Start / Misfire at high Idle
    Does it make any unusual sounds?
