mrfred54
    288
About mrfred54
    michigan
    anything Farmall or Red and Cub Cadet
447 profile views
  1. 1086 transmission trouble
    pull the pin on the transmissiom brake and try it........... does the ta shift ok?????
  2. 1066 with spare parts in hydraulic filter housing
    looks like a shifting cam roller. does the shifting seem sloppy for either the range tranny or the speed tranny. both use the roller for shiftforks.
  3. TA
    don't need a wrench for the clutch carrier. one of the slots on the nut will have a lock tab that will have to be bent up to turn the nut with a punch and hammer. usually not that tight. the planet carrier and ramp and roller unit removes from the rear. be sure to mark the unit before removing and the planet gears are all timed so be sure to find the marks on them
  4. TA
    I could rebuild it for you, but it would have to be after deer hunting season
  5. TA
    does it grind in high or low range or both and has it ever stopped moving in low. does the tractor grind while moving or in neutral. i'm probably around 50 miles from oxford
  6. TA
    do you know, is the ramp and roller bad or direct drive clutch. does the tractor stop when you pull the ta handle to the ta position or slip in direct drive
  7. 656 hydraulics
    are u using hytran oil...... had one a few years back with the same noise you talk about. changed his oil to hytran and the filter and the noise was gone. don't remember what oil he was using but seemed to be a higher viscosity
  8. TA
    yes what model tractor u got
  9. My daughters new Tractor
    congrats to your daughter, what a great story. love to see the young ones involved with these great machines. i'd be putting her name on future raffle tickets
  10. welcome to the forum.... first off, make sure the clutch has free play, at least an inch from where the pedal contacts the platform. also sounds like you need to change the hytran and filter
  11. Amazon is considering Pittsburgh
    cant see them coming to Detroit. they never find enough people that want a job, there happy with their welfare, ,,too lazy to get a job.........
  12. corn is late , really late
    corn here was between 13.4-- 17 before the rain this weekend been a real dry summer. this is our first rain since early august. way ahead of schedule...
  13. NAVISTAR, the rebirth of IH
    the road commission here has had ford tandems then sterling and now have and continuing buying Navistar tandems. they have been good trucks so far.
  14. National anthem protests
    they say this is their form of freedom of speech. well my freedom of speech is they are all a bunch of *&^&*&^%^&. they should all go to north korea and see how they like it. Thank a veteran today and tell the nfl to go where the sun don"t shine
  15. Farmall m serial number ???
    I also have a 51 M that my grandfather bought new. great buy and good luck with her.
