Brian stortenbecker
    1,612
About Brian stortenbecker
  • Birthday 11/17/1974
    Sw Iowa
    Family farms and repair shop owner. Family tractors- 706,806,806 wheatland,2-1206's,656,756,2-856's,856 custom ,1256,1456,826,666,766,966,1066,1466,1566,4166,886 narrow front,1486,460 gas,460-diesel 2-560 diesels, 8940, gold hood 305, 105u, dx60, 9370, 9390
1,714 profile views
  1. 3688 fuse diagrahm
    google carter and greuwald, they have wiring diagrams online.
  2. Someone needs to save this
    Yep I will get some pics. When she arrives.
  3. Someone needs to save this
    Going to it's forever home, here in SW. Iowa. Dad bought it.
  4. 400 series camshaft id
    I think you can tell with a dial indicator on the intake lobe. i will have to look at the specs from the older style cam till the later style.
  5. Oil pump and seal
    What I can see from the picture, I would replace the metal seal against the gear. Yep new key from case ih. I'm curious as to the shim stalk around the crank. Hope someone responds as to why it's there.
  6. Oil pump and seal
    Never seen a shim around the crank. The one by the gear is basically a seal to keep oil from seeping out. Looks like an old style crank key, I would update that.
  7. Other options for overhaul kits
    As far as sleeves, power bore cylinder sleeves are the best, i should call and see if they have a piston supplier.
  8. Other options for overhaul kits
    Matt endurance power was bought out by Reliance also.
  9. 1456 on Nebraska auction
    Was it the one on Lee Valley sale?
  10. MX 210 A/C drip hose
    Can i take the evap. core drip lines off under the cab and get them back on without having to remove the seat.
  11. DT407 overhaul help needed
    Number one main bearing is different than the rest besides the thrust bearing.
  12. Head gasket
    In tractor pulling, if you have enough to pull high 3rd. it will take the gasket out. thats no studs, just stock head bolts.
  13. Thin head gasket on 310 German 756
    Pete did the thinner gasket come out before the higher compression piston?
  14. Magnum 8920
    Jeff has it covered, one more thing, I had a guys 8920 doing same thing. Come to find out the cab solenoid would come on during the night. It would make just enough contact to turn radio on and drain batteries.
  15. 5088 clutch slipping
    Make sure your pedal is coming up, that it's not sticking, if that looks good check master clutch pressure, and see what you have there.
