Ian Beale
    890
About Ian Beale
  • Birthday
733 profile views
  1. Hope at hand https://wattsupwiththat.com/2017/01/13/not-tired-of-winning-yet/
  2. The Deltic was built for torpedo boats ( used in your Nasty class) and mine sweepers. A derated version was used in British Rail diesel electric locos. It ran the pumps in the Super Pumper fire engines. Major servicing was return to factory. Re costs etc " 04/12/03 I am sorry I cant give prices for the T18-37K engines but I can tell you the price in 1980 for the mine sweeper engines. The three engines cost on average £1000,000 and an overhaul now is around £300,000. Bear in mind these engines are only 9 cylinder but are produced in min mag materials. Mike B. " From a comment in "Discussions" at http://www.ptfnasty.com/ptfDeltic.html
  3. The Commer was even wilder than that - 1 crank,with each piston connected by 2 connecting rods and a rocking lever https://en.wikipedia.org/wiki/Commer_TS3
  4. Tcmtech So far Lock and Lubes work fine for me. Diameter is larger so they won't go on fittings in limited space. A nipple screwed into a standard coupler works for those. And (hopefully as it is used less often) will work longer.
  5. http://www.ranga.net.au/
  6. The cliffs are limestone Where the CO2 that had them worried way back then went https://en.wikipedia.org/wiki/Chalk
  7. Positive feedback Because the cutting edge is in front of the tracks when the tracks climbs a little the blade edge climbs more. Same when the tracks climb over the obstruction but now going down. So then the tracks climb that larger bump and the blade makes a bigger one for you to hit next. And so on till you quit and try again or start back bladeing. With practice can be countered by fine control of the blade. Not helped by any free play you have in the blade linkages. Whereas a grader has the blade between the wheels and the effect is minimised as the blade lifts less than the wheels
  8. But on the non lethal side we have a family of echidnas under the house and sheds. And I didn't charge extra for watering a little one from seeps from a water tank during the drought. Photos available if I work out how. https://en.wikipedia.org/wiki/Echidna Can be interesting if you're restumping and most of a mixer load disappears dowh an echidna hole though. My wife mutters about their ant chasing holes in the lawn. I tell her it is lawn aeration for free.
  9. And I'm not in this league either - so 12 gauge it would be if necessary A bloke in Cairns just expired from a taipan bite - that you don't need Apparently he was trying to grab it with a set of kitchen tongs to get it out of the house. I've got a scar to prove I've been bitten too. Was about 3 pm and nearly as far from base as possible. We were undoing the top barb ties in wooden posts to strain up the barb that had been belted loose by kangaroos. I was untying one post and felt a none too gentle wack on the hand. To see about a foot of a snake I'd never seen before out of the top wire hole. For ID purposes got the head end with pliers in the other hand. So back to home base with advice from my wife who is a nurse to do some sort of a tornequet - a bit of wire winding up the shirt sleeve. Son as driver. She elastic bandaged everything and pointed us to the nearest hospital. Where they worked out from the venom swab that it was tiger snake family (if you're ever bitten don't wash the area). Didn't need the head end. And we don't have tiger snakes so no antivenene. So it looked like for a while air freight to capital city. Me in best sartorial late afternoon working clothes, unshaven, dirty and no wallet. And the system gets you there and you have to work out how to get home. Ended up an ambulance trip to the next hospital and an overnight stay. It was a pale headed snake which is a climber.
  10. Does nothing good for polished floors either But they don't give a lot of snake grip and they're not so active when cooler
  11. lorenzo One can wouldn't do seeing as it is one of those houses on stumps. Likely came up the steps and under a door Sledgehammer Close range 22 rat shot works better on floors
  12. Stageone You know that "positive feedback" is one of the necessities for the dire results predicted of CAGW? Well the only positive feedback I can think of is when trying to grade with a dozer blade. More horsepower seems to help. And more practice. And then we got a grader.
  13. Pre breakfast excitement of yesterday morning here in this part of Oz was about 6 feet of brown snake IN THE HOUSE
  14. FWIW Power Farming Annual 1970 (Oz) TD 20 B Engine "IH 4 stroke, turbocharger diesel. cylinders 6. bore 4.5", stroke 4.5". Displacement 429 ci"
  15. I've said for years that we didn't need it washing up on the east coast of Oz
