Ih784
    14
About Ih784
101 profile views
  1. I used castrol HD30 in IH D246 engine HELP!
    Roger that. That's what I was feeling. I understand "diesel oils" have different additive packages. I mean it's not like I thinned it with kerosene or used a synthetic or multi weight oil. I don't have anyone to bounce questions or ideas off of. I sincerely appreciate your responses like the one guy said: "at least it's oil" lol. Ima letter roll.
  2. I used castrol HD30 in IH D246 engine HELP!
    I wasn't sure what it would do to the oil I'd already used? I try to keep my things in good order. I was only concerned. Thank you for your response.
  3. Hey folks, I just change the oil on my international 784. The first 2 gallons with shell Rotella T one . I'm accidentally filled the oil filter with Castrol HD 30 half to 3/4 of the way. Then Installed oil filter and ran the engine. How much damage if any do you think will this cost to the engine if ran very minimal for the next six months?
  4. Hey folks, I just change the oil on my international 784. The first 2 gallons with shell Rotella T one . I'm accidentally filled the oil filter with Castrol HD 30 half to 3/4 of the way. Then Installed oil filter and ran the engine. How much damage if any do you think will this cost to the engine if ran very minimal for the next six months?
  5. International 784 power steering cylinder
    Thanks to both of you for the advice! Nothing's too worn for needed replacement. I'll certainly try the electrical tape with the hose clamp idea.
  6. International 784 power steering cylinder
    Those outer wipers (the one installed is cracked now).Also I seem to have stretched out the white Teflon seal that goes on the piston. Do you guys think I need a new one? It seems pretty tight going into the cylinder bore.
  7. International 784 power steering cylinder
    The rebuild kit came from the dealer. I got it out and cleaned up. I'll repack it tomorrow. There's two hard plastic pieces that go on the ends. Any trick to popping the old ones and the new ones in? Im glad you guys are around lol.
  8. I have an International 784 that needs to have the power steering cylinder rebuilt. I have a couple of questions. Will the lines need to be capped off while I repack the cylinders? I'm aware that debris may enter the system if I don't. My concern is that will it continue to drain hydraulic fluid other than what's in the lines? Anyone with any advice on re packing these guys is much appreciated to chime in lol. Thank you so much in advance!
